Do you run a dumpvalve with your gt series turbo? And why?
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
As the title says. Do you run a dumpvalve with your gt series turbo.
I currently run one with a gt35, as I've heard the shafts are weak and do not want a failure.
What is your opion?
Cheers Aaron
i run a dump valve but then its always been on the car i have it to stop compressor wheel stall as i run a high boost level (2.6bar) i also have mild anti lag via my autronic ecu
