short stud head bolt kit cosworth?
Old Mar 2, 2012 | 09:06 AM
dingla rs's Avatar
dingla rs
Default short stud head bolt kit cosworth?
i know you can get a long stud kit that means the block needs machining for them ,but were can i get a short stud kit that means no machining? any one help me on this as iv been told you can get them ? also has anyone had there oil pump reconed? for 4x4 cosworth btw
205 blOck
cheers andy
Old Mar 2, 2012 | 09:15 AM
DAN-Saff's Avatar
DAN-Saff
I think your talking about arp head bolts
Old Mar 2, 2012 | 09:17 AM
dingla rs's Avatar
dingla rs
any idear were from tho mate ,thanks
Old Mar 2, 2012 | 10:06 AM
DAN-Saff's Avatar
DAN-Saff
Do a search for arp stud and nut kit on google and you can find a supplier, but they are frowned on tbh for causing probs do a search on here aswell and read the posts.
Old Mar 2, 2012 | 10:19 AM
bad boy rs's Avatar
bad boy rs
sick with standard bolts depending on power, as above herd stories of them cracking blocks but think that was down to not being fitted correctly
Old Mar 2, 2012 | 10:44 AM
dingla rs's Avatar
dingla rs
Did a google look ,it's a multy layer head gasket an
Block been decked around 450 ,may stick to
Genuine ford head bolts then
Old Mar 2, 2012 | 10:56 AM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
Genuine Bolts Andy i have a set here for you if you still want them..............i forgot to call you back
Old Mar 2, 2012 | 10:59 AM
dingla rs's Avatar
dingla rs
Will bell you in but then mate thanks
Old Mar 2, 2012 | 03:53 PM
dingla rs's Avatar
dingla rs
all sorted new oilpump an head bolts on way off matt ,thanks for info guys
Old Mar 2, 2012 | 05:02 PM
Rsmat's Avatar
Rsmat
Arp need to be fitted correctly... But standard headbolts fine... I run arp.. For them from woodford last year.
Old Mar 2, 2012 | 05:08 PM
Matt Lewis's Avatar
Matt Lewis
thanks for the order Andy will land Monday keep an eye on your emails delivery info has been added
Old Mar 2, 2012 | 05:26 PM
andrewg's Avatar
andrewg
i have set second hand ones!
IAN RS2k
Aug 18, 2015 07:51 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
