Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
99 focus Zetec s engine question
Old Feb 29, 2012 | 09:51 PM
brnys85's Avatar
brnys85
Default 99 focus Zetec s engine question
Hi there, I've just bought a focus with a knocking big end. Took the sump off and its full of metal.... The big end bearings were wafer thin and deformed which has killed the crank journals etc.
My question is are all engines from 98-04 so zetec s silvertops and se blacktops interchangeable? I'm just going to stick another 1.6 lump in.
I've heard early mk5 fiestas are the same (just use the origional mounts) there just seem to be more blacktop 1.6 se engines about. I'm desperate for an engine as its my transport.....
Sam
Old Feb 29, 2012 | 11:03 PM
martysmartie's Avatar
martysmartie
The early engines had a metal cam cover enscribed "Zetec-S", the later ones were plastic and had "Zetec-SE" printed on them, these are known as phase 1 and 2 engines respectively.
The engines are the same, phase 2 engines had slight enhancements in the head but it's still the same engine none the less.
The Fiesta Zetec-S model, again used the same engine borrowed from the Focus.
These are "Throw away" engines, i.e. due to the design of the engine block with a ladder style crankshaft iirc you cannot rebuild them.
Martin
Old Mar 1, 2012 | 07:13 PM
brnys85's Avatar
brnys85
thanks for the great info, i'll go get set searching for a reasonably price engine!
Old Mar 4, 2012 | 12:34 AM
Straight_4_N/a's Avatar
Straight_4_N/a
get in contact with shawspeed thay can rebuild these...
on the other hand ive got a spare 1.6 going cheap
Old Mar 4, 2012 | 12:42 PM
brnys85's Avatar
brnys85
Typical! I went and picked one up yesterday for 150 lucky it wasnt too far away as well.cheers though
JoeyBoyden
Jan 4, 2024 02:36 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
