gauge question
Old Feb 25, 2012 | 10:13 AM
STeve_170's Avatar
STeve_170
Made In Wales
Default gauge question
My oil temperature and water temperature gauges are baffling me. When the car is stood still they show the correct reading, but when the car is in motion they both drop to minimum The oil pressure gauge works perfectly but only the other 2 play up. Its only happened since its last service also if that helps. Any suggestions??
Old Feb 25, 2012 | 10:38 AM
oldford's Avatar
oldford
Maybe the engine temperature is dropping, caused by a defective thermostat?
Does it take long for the car to warm up in the morning?
Does the radiator and the top hose start to warm up slowly immediately after starting the cold engine? When yes, thermostat stays open and needs to be replaced.
Old Feb 25, 2012 | 01:42 PM
STeve_170's Avatar
STeve_170
Made In Wales
It doesnt take too long to warm up really. Havent checked the pipework yet but will do. Would this affect the oil temperature also? Thanks for the info too mate
Old Feb 26, 2012 | 05:56 PM
danme1987's Avatar
danme1987
I was having gauge problems and it was my thermostat. An yes it affected my oil temperature
Old Feb 26, 2012 | 06:02 PM
RichieST's Avatar
RichieST
As above, same on my old st170. Sticky thermostat!
Old Feb 27, 2012 | 09:00 PM
red sport's Avatar
red sport
change the thermostate and this will sort your problem
Old Mar 3, 2012 | 10:32 AM
STeve_170's Avatar
STeve_170
Made In Wales
Lovely thank you guys!
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
