ST170 Clutch pedal clicks when being depressed
Old Feb 22, 2012 | 08:37 AM
leebroath's Avatar
leebroath
Default ST170 Clutch pedal clicks when being depressed
Hi guys
I've got an ST170 2003 model mk1
I have a problem with the clutch, it clicks when you lift off the pedal after it being fully depressed
I've been in all sorts of funny angles upside down with my head stuck in the foot well trying to push on the clutch then releasing it to listen for the sound and where it's coming from. I don't think the system needs bled either.....but haven't tried it
Tried the Lithium white spray grease on all moving parts and it's def not that, I have went an ordered a new Master Cylinder as I think that's where the problem exists.
Also to note, when working the clutch and braking you can feel the clicks through the brake pedal also.....it's so annoying
I was wondering if anyone else experienced this same problem and is the Master Cylinder the root problem ??
I have uploaded a video of the clicking to let you all hear
http://www.youtube.com/watch?v=Vw9vNhbUZno
Old Feb 22, 2012 | 04:24 PM
leebroath's Avatar
leebroath
....... anyone ????
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
