ford fiesta 1.6 tdci Zetec S wont turn over
Old Feb 19, 2012 | 09:25 PM
Pit Pony's Avatar
Pit Pony
Default ford fiesta 1.6 tdci Zetec S wont turn over
My Sons 2007 fiesta Zetec S wont turn over , he went to a football match and when he went back to the car he heard the fan running, when he tried to start the car the ignition lights etc all came on but the car wouldn't turn over. We have tried bump starting , towing it re-charged the battery, checked fuses and relays , tried spare key... No Joy, does anyone have any idea???
Cheers Steve.
Old Feb 19, 2012 | 11:53 PM
studabear's Avatar
studabear
does the engine turn?
Jack the osf wheel up, put it in gear and turn the jacked up wheel, the engine should turn.
Old Feb 20, 2012 | 07:35 AM
Faulty starter motor?These fiestad have the peugoet diesel engine in them so that will be the main problem lol.
Old Feb 20, 2012 | 08:28 AM
Brendan's Avatar
Brendan
struggling with reality
can you hear the realys click as you start it up? and does it turn over? Do the correct lights come in as you go through the start up sequence?
If this is the case it could be an imobiliser prob! Try disconecting the batery for a few hours and starting then! if this works you need to let the ecu learn the engine again!
good luck.
Old Feb 20, 2012 | 10:41 AM
B19 JUB's Avatar
B19 JUB
id say cooling fan relay has stuck causing battery to drain.jump leads for about 10 mins should start it.if the fan is still running try tapping the square box behind the battery to free off the relay.seen a few do this at my time at fords
Old Feb 20, 2012 | 06:24 PM
Pit Pony's Avatar
Pit Pony
Thanks everyone for your replies, the car is at a garage now, possible ECU after loads of errors showing on computer. Tip worth knowing, the electric fans speed is regulated by the ECU so if it kicks in at full speed its a sign that the ECU is not controlling it as it should be. Were hoping for a connection problem but realisticaly it doesn't look good.
Old Feb 20, 2012 | 06:28 PM
Pit Pony's Avatar
Pit Pony
Lightbulb Why didn't I think of that DOH !!!!
I hope you're joking
vaughant's Avatar
vaughant
Gutted for you,hopefully it can be sorted.
Amazing how shit they build newer cars,always seems to be something or other going wrong with them.
Old Feb 20, 2012 | 07:35 PM
Pit Pony's Avatar
Pit Pony
Too true my son thoughtr he would buy a sensible car that he could run for a few years . I run a couple of Triumph Spifires !!!! they never break down cos there's nowt to go faulty..LOL
Old Feb 20, 2012 | 07:56 PM
vaughant's Avatar
vaughant
Yeah I love older cars.
Is there petrol?yes.is there a spark?yes.well,it must be fucked then!!!!
Oh no,I didn't notice the wire came off the coil,quick lengtupon wire up to the battery and your back on the road!!!
I'm sure the car will be fine once you've sorted it now,and for your boy 50/60 mpg is always handy!!!
Old Mar 1, 2012 | 06:39 PM
Pit Pony's Avatar
Pit Pony
Default SORTED!!!!
If your fan is stuck on at full speed it could be a problem with the ecu not comunicating with the dash clocks......turned out to be the clocks that caused the fault......new clocks Ł250.00......Recomend M-Tech at Wath nr Barnsley South Yorkshire......He was brilliant....
Old Jul 7, 2016 | 11:28 PM
Jordan Moulds's Avatar
Jordan Moulds
Default ford fiesta zetec s 1.6 tdci wont turn over!
After dropping my key, I went to my car its started up fine drove it about 5 mile and my stereo went off the abs light, battery light, power steering light (no power steering), air bag light came on also kept telling me the handbrake was on, i drove it steady to find somewhere to check the problem and as i pulled up all the light on dash went out i had nothing but engine was still running turned the car off and now it wont start not even wanting to turn over, the immobiliser light just flashes like made, but all the right dash lights come on as normal, i've checked fuses, put new battery on and there is nothing, could i have a faulty starter motor or could it be the ECU!!
Botts
Aug 13, 2015 04:16 PM
