YB water system
Old Feb 19, 2012 | 09:07 PM
jamie956's Avatar
jamie956
Default YB water system
Can someone help me figer out my water system 2wd yb in to a cortina,
no interia heater, no oil cooler, no turbo cooling.
A diagram would be great a help.
Old Feb 20, 2012 | 08:17 AM
Brendan's Avatar
Brendan
struggling with reality
Haynes manual will have this in for you! I also have a list of web sites with manuals in if you want! PM me your email address
Old Feb 20, 2012 | 09:23 AM
BRAMMER's Avatar
BRAMMER
If no heater would the pipe that runs down the turbo side of the head just go to the outlet on the rear of the inlet side of the head - simple plumbing -
use the original cosworth metal water pipe from the water pump down the side of the head then 90° - straight - 180° in to the head
You don't need to use a water feed on the oil modine sojust a normal radiator kit
Old Feb 20, 2012 | 10:22 AM
joffy's Avatar
joffy
SLOW LEARNER
i THINK (not 100%) you can just blank off the outlet on the thermostat housing that goes to the turbo and then again on the header tank, as said the water for the heaters goes along the drivers side of the block in the metal pipe, around the back of the block and into the back of the engine on the passenger side, i am in suffolk (lowestoft) and have a saph and 3 door if you wanna have a look?
Old Feb 20, 2012 | 08:24 PM
jamie956's Avatar
jamie956
Hi that would be great as im in lowestoft as well may be drop you a pm at the weekend.
Old Feb 22, 2012 | 11:58 AM
joffy's Avatar
joffy
SLOW LEARNER
no probs mate, you have PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
