Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
hand brake problem
Old Feb 19, 2012 | 05:59 PM
rick denny's Avatar
rick denny
Pontiac drag racer
Default hand brake problem
I`ve just replaced the discs all round on my 2003 Focus. I can`t reconnect the handbrake cable on the driver side, the passenger side is on. How do you loosen off the cable to hook it up? do you have to adjust it from the handle under the car?
Old Feb 19, 2012 | 06:19 PM
martysmartie's Avatar
martysmartie
There are both, a plastic adjuster nut and a locking nut on one side of the cable, you undo the locking nut and then undo the adjuster this will give you slack in the cable to hook over the handbrake 'hook' on the caliper.
I don't see why you have taken it off though if your just replacing discs?
Martin
Old Feb 19, 2012 | 06:56 PM
rick denny's Avatar
rick denny
Pontiac drag racer
It gave me more room to wind in the caliper and also to get my hose on the bleed nipple.
I didn`t notice a plastic nut it looked all in 1 piece at the bracket onto the caliper.
Old Feb 20, 2012 | 12:30 PM
martysmartie
You will need to be underneath the car to see it, it is not near the end of the cable, it will be on either the nearside or offside cable, follow each back toward the actual lever and you will see it.
Martin
Old Feb 20, 2012 | 06:36 PM
rick denny's Avatar
rick denny
Pontiac drag racer
I did from inside the car. adjusted the nut that holds the cable to the lever itself which is under the handbrake boot.
Old Feb 21, 2012 | 12:21 PM
martysmartie
Same thing really, on older cars it was on the cable underneath the car, where as on these it must be moved to the lever itself.
Martin
Old Apr 10, 2012 | 04:37 PM
jakerobert's Avatar
jakerobert
Hi all the hand brake on my focus 2003 has become slack i heard that the rear ajusters are common not to work to well and this is most likley the fault any body els no anything cheers.
Old Apr 10, 2012 | 06:09 PM
martysmartie
It should be self adjusting, it seems from above it can be adjusted from the lever, going by that I should think that the adjuster may be built into the handbrake lever itself.
Martin
Old Apr 10, 2012 | 06:56 PM
jakerobert's Avatar
jakerobert
Cheers martin just looked there is an ajuster under the hand brake might still drop it in on the theory the ajusters on the shoes aint all that.
Old Apr 10, 2012 | 08:20 PM
martysmartie
Are the shoes in good condition?
Martin
Old Apr 12, 2012 | 08:19 PM
jakerobert's Avatar
jakerobert
???????? Marti i dont know about the shoes gonna take a look the week end i spoke to a local garage he said 9 times out of 10 they just dont ajust like they should
Old Apr 12, 2012 | 10:49 PM
Straight_4_N/a's Avatar
Straight_4_N/a
you have done somthing wrong and i know what it is, you have fitted the pas caipler havnt you (with the cable on it) ? and what happens then is it pulleys the other side of the cable which makes it realy tight you can pull the drivers side up but then you also have to push the leaver on the caipler to so the easyest thing to do is take both caiplers back off and fit the cable first then fit caiplers back on.
Old Apr 12, 2012 | 11:03 PM
Straight_4_N/a
sorry i dont know if that makes sence to you heres how to do it from the start.
put hand brake off
remove wheel
remove caiplers
remove discs
refit new discs
fit caipler holders
fit new pads
ensure hand brake cable is still on both cailpers
wind the pistons back in
fit caiplers
next bit is easyer with two people (now i cant excalty rember how to do this bit and i dont want to say the wrong way but i rember one of you has to be in the drivers seats either pulling up the hand brake or pushing the foot brake and you have to push the cailper leave up)
and fit the wheels and your done
Old Apr 14, 2012 | 04:20 PM
martysmartie
It does not have rear discs.
Martin
Old Apr 14, 2012 | 11:37 PM
Straight_4_N/a
Martin
sounds like it does have rear discs from what hes saying, otherwise he would of say just replaced the rear shoes and cant connect the hand brake cable but he said he toke the cable off to wind the caiplers back in hence he has discs all round
Old Apr 15, 2012 | 03:06 PM
martysmartie
My bad, just re read initial post (In fact I even mention discs then I start talking about shoes hence me thinking drums), I really need a holiday right about now!
Martin
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
muz
Aug 1, 2015 06:48 AM
