st200 recon injectors off ebay
Old Feb 18, 2012 | 09:06 PM
blakey100's Avatar
blakey100
Default st200 recon injectors off ebay
hi,
i have an st200 90000 on the clock now was thinking about buying these recon injectors off ebay, has any one bought these and noticed any difference in perfomance, iv tried redex injector cleaner and dont fancy buying these new from ford as was quoted 147 plus vat each
Old Feb 18, 2012 | 09:10 PM
Bailes1992's Avatar
Bailes1992
I don't think it's too much of an issue on petrol cars, ecspecially indirect injection engines.
As the petrol is just sucked into the cylinder it dosen't make a difference how it comes out really, aslong as it's in the right quanitity.
Direct engines are different as they have to have a specific spray pattern.
Diesel engines are different again as the spray pattern alters and hurts the performance.
Old Feb 18, 2012 | 09:16 PM
blakey100's Avatar
blakey100
so u dont think it might help restore the original bhp, i remember an old top gear where they were trying to make that renault go faster round the track and they replaced the injectors and it was close to its original bhp
Old Feb 18, 2012 | 09:26 PM
Bailes1992's Avatar
Bailes1992
No they did abit more, cleaned out the manifolds, polished the heads, headgaskets, cleaned the bores etc etc
Old Feb 18, 2012 | 10:58 PM
alexno1dj's Avatar
alexno1dj
sorry to discuss another ford but what type of injectors does a puma use?
Old Feb 18, 2012 | 11:54 PM
xr4x4rs's Avatar
xr4x4rs
the mondeo suffers from bad coke build up in teh lower inlet manifold due to poor breather design
best thing to do is go get new gaskets for inlets, take inlets off and soak them both in degreaser or brake cleaner and clean as much as you can, while your doing it you can also send your injectors to do an ultra sonic clean which will restore the injectors anyhow
but they st also suffers with the imrc so this could be failing stopping the secondaries opening , so posisbly relocating it under the battery while everything is off as at the minute its directly above the exhaust manifold which cooks the circuit boards inside it
Old Feb 19, 2012 | 03:29 AM
Chaz888's Avatar
Chaz888
Mr 4x4 is spot on Its the EGR that puts all the shit in the manafold so yer clean it out ! also you can tune up the throttle body and lower intake butterflys by replacing the screws for dome allen bolts and half cut the spindel and knife edge the TB plate and polish the bore
Old Feb 19, 2012 | 09:16 AM
Graceland's Avatar
Graceland
Team HOTHOT!
I think you need to have a read about how an EFI fuel system works and fuel atomisation - What you have put there is seriously way off the mark.
Have a read of this technical article and you'll see why
http://www.motorsport-developments.c...AF293_tech.pdf
Enjoy
Old Feb 19, 2012 | 10:56 AM
Bailes1992's Avatar
Bailes1992
Enjoy
Hmmm... never thought too much of that.
Turns out I'm wrong
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
Fil
Sep 30, 2015 12:08 PM
