where can i get this bit from (pinch bolt conversion)
Old Feb 18, 2012 | 05:29 PM
andy escos's Avatar
andy escos
Question where can i get this bit from (pinch bolt conversion)
as title i can not think what they are called but i have seen them in the past for sale any help would be appreciated thanks .
the bit in the circle .
Old Feb 18, 2012 | 05:41 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
not sure on the name ,
but im 99% sure mcgill stock them mate !!
Old Feb 18, 2012 | 05:54 PM
andy escos's Avatar
andy escos
i have had a look at there site but they do not do them with the original pinch bolt style
thanks for the thought though mate
Old Feb 18, 2012 | 05:56 PM
JonnyBravo's Avatar
JonnyBravo
I think they are custom made mate, my Pug runs the same sort of thing as its a ball joint on the bottom into a stock saph upright.
If their Marcs I would imagine Andrews mate ( Omni tool is it ?? ) probably machined them to his specs.
Ignore the angles that everything is sat at in this pic but these are mine, would effectively be the same setup on the bottom if your using a standard upright.
Old Feb 18, 2012 | 06:54 PM
andy escos's Avatar
andy escos
i suppose i could always do the pinch bolt up & then drill through the bottom of the carrier , if i could not get the pinch bolts .
Old Feb 18, 2012 | 09:03 PM
jamie956's Avatar
jamie956
Have you got the TCA's they look like a set of Alan Dents, here are his and the pinch bolt pins.
http://www.ebay.co.uk/itm/Ford-sierr...item1e6aa27961
http://www.ebay.co.uk/itm/sierra-cos...item20c19f3133
Old Feb 18, 2012 | 09:09 PM
Miller 3's Avatar
Miller 3
I recognise that pic lol
As above Andy mate www.alachi57.com
Old Feb 18, 2012 | 09:30 PM
andy escos's Avatar
andy escos
ha ha yes mate there your tca,s i bet you guessed what im going to be doing later on then
i thought Tony made them or do Tony use Alan Dent to make his parts
Old Feb 18, 2012 | 10:37 PM
Miller 3's Avatar
Miller 3
Alan was making them for Tony mate.
Old Feb 18, 2012 | 11:07 PM
JonnyBravo's Avatar
JonnyBravo
Good value for money !
saul1988
Wheels and Tyres
Aug 24, 2015 06:42 AM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
