Just been to msd
Well just on the way home from msd as me mate wanted his car setup nice bunch of people There. an hes come home with nearly an empty wallet now to fit the rear diff mount this should be fun
diif mounts a piece of piss to fit,support diff with jack ,unbolt 4 support bolts of old mount and the 2 bolts holding mount to diff.all goes back the same way.make sure rear of car supported with 2 axel stands(use a little lock tight as the bolts can work loose)
They're a 15 min job once its on the lift... As long as all the bolts come out oK!
JK12
33
Apr 26, 2021 12:09 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
