St170 ITB/Piper Cams problem
Old Feb 16, 2012 | 08:23 PM
rhinopower's Avatar
rhinopower
Default St170 ITB/Piper Cams problem
After any ideas, I've bolted my ST170 head back on having got it back from the machine shop who shimmed all the lifters for my piper 285 cams, but im finding atleast when the car is idling, im getting pulses of air coming back out of the throttle body on cylinder 3. Its definatly not exhaust gas, and the car is idling ok otherwise, no misfire etc.
My only thought so far is to check valve clearance on that cylinder, but if the valve was sitting open then surely it would be exhaust gas coming back out.
The inlet cam still needs timing for peak power, but certainly should of been ok for idling.
Old Feb 16, 2012 | 10:07 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Have you done a compression test since refitting the head?
Old Feb 16, 2012 | 10:26 PM
rhinopower's Avatar
rhinopower
Due to lack of a compression tester no, i'l go out and buy one tomorrow. The head was skimmed with new headgasket and bolts used.
Old Feb 16, 2012 | 10:57 PM
JPA's Avatar
JPA
not 100% correct mate , get the valve clearance checked , if its too tight you will have this problem @ idle with just a wee bit too much overlap
john
Old Feb 16, 2012 | 11:09 PM
rhinopower's Avatar
rhinopower
john
I might loose the overlap when the inlet cam timing is adjusted, but i would of thought this would affect all 4 cylinders. Clearances will be first check before i buy a compression tester.
Old Feb 17, 2012 | 02:00 AM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
If its just 1 cylinder (you said its on ITB's) then it has to be a valve clearance issure on the inlet side, make sure the valve is closing as should and make sure its sealing correctly etc
Old Feb 17, 2012 | 08:17 AM
rhinopower's Avatar
rhinopower
Clearance is fine. Compression check it is then.
dombanks
Sep 21, 2015 08:38 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
grishenko45
Sep 9, 2015 12:58 PM
rog
Sep 4, 2015 07:24 AM
