Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
st170 random sensor cable tied near battery? hhhhelp please!!
Old Feb 16, 2012 | 02:24 PM
skypeller's Avatar
skypeller
Default st170 random sensor cable tied near battery? hhhhelp please!!
just found the brass looking sensor which i can only assum is supposed to be plugged in somewhere near to where it is now because the wiring loom looks original and uncut.... also i have a very tiny thermostat leak looks like a plug which is at the bottom with a wierd spring clip is simply leaking
Old Feb 16, 2012 | 02:41 PM
skypeller's Avatar
skypeller
Can anybody confirm what this should be doing and where all the temp sensors are located as the car rises to normal temp and normal rate all seems ok ???confusing
Old Feb 16, 2012 | 03:29 PM
skypeller's Avatar
skypeller
can confirm this was a sensor fitted to monitor enginebay temp as a recall by ford
Old Feb 16, 2012 | 05:36 PM
GVK.'s Avatar
GVK.
Yep, was a recall when cars were new, fans would cut in if underbonnet temp got too high.
Old Feb 20, 2012 | 07:39 AM
Ive seen this on a few focuses the 1.8 and 2ltr zetecs are the same.
Old Feb 28, 2012 | 09:52 PM
Greasenuts's Avatar
Greasenuts
thats a relief, mines the same and i was gonna spend my next free saturday looking for where that should be located! Cheers for that!!!
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Bransby
Sep 14, 2015 08:54 PM
