Focus 1.8td injection pump removal
Old Feb 15, 2012 | 08:45 PM
Trist's Avatar
Trist
Default Focus 1.8td injection pump removal
Is there anywhere on Internet that has timing marks to remove the fuel pump? Is there holes in certain pulleys and flywheel?
Can you lock the pump off so I can send it away?
Thanks.
Old Feb 16, 2012 | 08:33 AM
The cam belt only drives the cam and the pump the crank is chain driven.Im sure the pump is easy to remove.
Old Feb 16, 2012 | 10:53 AM
gouch1's Avatar
gouch1
i did mine a while back eng mount has to come off,alternator belt ,alternator and bracket has to be removed. timing cover then belt,
then there is inner covers / casings, to expose chain wich goes from crank to pump.
under the rocker cover the cam locks in place with a flat bar at gearbox end of cam
the pump is a six mill drill bit if i remember right and the cranck locks with a tool or (home made via bolt) behind the alternator bracket i found it easyer to buy the manual for refrence and it tells you how to make a locking kit.
haynes manual halfords 20 quid
Old Feb 17, 2012 | 08:08 AM
Trist's Avatar
Trist
Thanks.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Aug 29, 2015 08:16 PM
Adam-M
Aug 26, 2015 05:53 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
