Need Help. Any experience will be helpful.
Old Feb 15, 2012 | 03:48 PM
Lewis-Durkin's Avatar
Lewis-Durkin
Default Need Help. Any experience will be helpful.
Hi guys and girls.
Im Knew, Ill update all my profile and get photos on after this.
I've owned my 1.1 fiesta for 2 months now and first problem was the alternator!
It got a new one but the pulley doesnt seem to spaced properly! soo of came the fan belt on the M62 causing the coolant to boil!
Next thing ive noticed is ive got some un wanted camber on the front wheels, and this is eating tyres. ive been told because it been lowered ( 30mm springs) is this true? and how do i solve the problem? because ive got some xr2i alloys that i am refurbing and going on.
any help and advice will be greatly appreciated
Thanks Lewis x
Old Feb 15, 2012 | 09:27 PM
Dan_RS500's Avatar
Dan_RS500
Lowering the car will cause negative camber but will also cause toe out, which is more than likely the cause of the tyre wear. Have the wheel alignment checked by a competent garage. There are things you can do to correct the camber but a bit of negative camber on the front is good for the twisty stuff!
Old Feb 15, 2012 | 09:36 PM
mrjenrst's Avatar
mrjenrst
where you based mate
Old Feb 17, 2012 | 09:40 PM
Lewis-Durkin
cheers ill get them done. im just refurbing my xr2i alloys then im gonna get them balanced and so the tracking hopefully that will sort it.
And im from Goole East yorkshire mate. x
Old Feb 17, 2012 | 09:51 PM
xr4x4rs's Avatar
xr4x4rs
what year fiesta is it, as its common on the mk3 for bushes togo in front arms which cause problems aswell
alternator did you use youroriginal pulley? as there is also a spacer behind the pulley
Old Feb 17, 2012 | 09:54 PM
xr_craig's Avatar
xr_craig
As said, tracking is probably the issue. Your local to me too. I use Dave at Savoy tyres in Howden, he always moans/takes the piss but he is always happy to sort my tracking out.
Old Feb 19, 2012 | 09:31 AM
Lewis-Durkin
hi you two thanks for the reply.
good to know of some people on here near me.
you familar with TS motors in goole? thats my mates dads garage
what car you driving around in? ill keep an eye out.
Old Feb 19, 2012 | 10:47 AM
xr_craig's Avatar
xr_craig
Yeah i know TS motors, not used them for a while though. I'm using a blue mgzt at the min.
Old Feb 19, 2012 | 01:58 PM
Lewis-Durkin
sweet my cars off the road for some work but its a red mk 3 fiesta
Oranoco
12
Oct 2, 2015 02:18 PM
muzzman1
Sep 30, 2015 08:59 PM
TC-ST3
Sep 26, 2015 04:47 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 11:21 AM
