anyone here test 7.5 tonne trucks?
I'm in need of some advice regarding an exhaust brake if anyone can help?
short story is, got a 7.5 tonne daf recovery truck, broke down one day due to the exhaust brake sticking on, fitter came out, smacked it with a lump hammer (as you do) which released it and told me to carry on, a defect report was handed in when i got back to the yard but rather than fix the problem the answer has been to disconnect the bloody thing!
now i'm unsure how this stands on a legallity side of things, if said vehicle was to get pulled by vosa how would they look at it? if it was involved in an accident what would the view be on it? basically i'm trying to cover my own arse here as it's always the drivers resposility etc.
thanks in advance for any help.
From 1st of April exhaust brake must work for test and no you can't just remove it.check visa web site for the lattest 22 changes to the test
CheeRS stu
CheeRS stu
well taken from the test manual online:
Method of inspection,
Check aditional breaking devices for:
a. presence when known to be a mandatory fitment.
b. operation, condition completeness, and security.
c. security and condition of wiring.
Reasons for failure
1. An additional braking device:
a. missing when known to be a mandatory item.
b. inoperative, damaged, component missing, or insecure.
c. wiring insecure or damaged.
seems simple enough to me that it needs to be fixed and not ignored?
Reasons for failure
nope, i'm a mechanic for the company, i do vans and cars etc but when things go a bit quiet i often go out shifting cars between garages within our company or doing recovery work with the truck.
think that's what's pissing me off more than anything, there's plenty of people in the company who know the law etc but they would rather just have an easy ride insted of taking a few minutes to fix a problem.
the very same thing used to happen on my 7.5t lorry that i used to drive for a company. i used to keep a hammer and would often give the exhaust brake a tap if it got stuck on. the other option is not to use the exhaust brake atall, just leave it turned off. or if it bothers you that much just dont drive it and tell the company why. aslong as you fill in a defect report the blame falls onto them for not fixing the problem, i cant see you crashing the lorry because of that problem anyway. its a minor issue in my opinion.
TPM961
Jan 15, 2018 10:50 AM
