1.6cvh NMS Red s2 project..Fitting a T34 and raising the boost to 27psi.
Old Feb 8, 2012 | 05:10 PM
Joe91's Avatar
Joe91
Default 1.6cvh NMS Red s2 project..Fitting a T34 and raising the boost to 27psi.
Hi all, as some of you know im having my engine built at norris motorsport, the engine will be ready next week so im starting to strip my engine down and getting it ready to be removed to fit the new one, couple of pictures of before etc and where i am now, then ill upload them as the new engine goes in and the mapping/work is done on the car.
The engine spec will be:
NMS bottom end
Cosworth mahle pistons 0.75 oversize.
Robson engineering EN24T H section con-rods custom made to NMS specification, shot peened and fitted with ARP big end bolts.
Original sump blasted, cleaned and painted in 2 pac black paint.
New modified oil pump, for high flow and high pressure.
NMS head work to flow up to 280bhp (For now)
Newmans phase 4 fast road cam, solid lifters and single valve springs.
2.5" exhaust with 4" tip
FMIC twin fans
T34 turbo
Group A k&n
Omex 600 managment, will have the anti lag and launch control on after running in.
Mk1 focus rs injectors.
ST170 300mm brake conversion, grooved disks and yellow stuff pads.
Thats about it for performance parts, all i can do it wait until i get the car up to Karl and Oli and let them work there magic on it!
Pictures to follow..
Old Feb 8, 2012 | 05:37 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
sounds like its gonna be good mate get some pics up when you get chance
Old Feb 8, 2012 | 06:53 PM
BlackSaff's Avatar
BlackSaff
You won't go wrong with an NMS build fella, my ERST flew after Karl had his hands on it.
Old Feb 9, 2012 | 03:49 PM
Joe91's Avatar
Joe91
Couple of pictures from before i started taking the engine out..
putting the new head on, and having the omex fitted last summer..
T34 going on.
Couple videos of it on the rollers having its base map.
Got to love some red glowing!
Next up was the brake conversion, dont have many pics just the final look.
What i was left with over my car was a layer of metal filings from the grinding of the calipers to fit under the standard 15's, which soon turned to rust in the rain, so out came some little treats from the detailing kit.
Purple liquid indicates the metal filings.
Oh and the result of me putting my fingers in between the spokes to feel the gap, which my mate then decides to turn the wheels..Ouch is a good word to use.
Just incase you couldnt make out the above picture..My nail has since fallen off and grown back again!
Then the headgasket blew on my running in miles, approx 600miles, only just found out the reason which my original tuner should have told me, it was becasue i was using a head that had the oil/waterways for a zetec block rather than cvh so the headgasket obviously couldnt do its job! very annoying but not to worry.
Already had the head off at this point because it blew the gasket so a couple of pics as to where i am now.
Turbo out.
More stuff out.
As it stands now, Going to respray the engine bay whilst ive got room.
Today ive been preping the rocker cover ready to spray it black.
Will update as and when the engine comes out, Think im removing it on sunday.
Thanks, Joe
Old Feb 9, 2012 | 04:35 PM
Maxwell's Avatar
Maxwell
Irregular Poster
fuck me your finger looks sore as!!!!
as for your rocker cover, a powdercoaters could have blasted that and recoated it in a colour you want, for around Ł15!!
keep the updates coming!
Old Feb 9, 2012 | 04:48 PM
P 17eed's Avatar
P 17eed
What's involved in fitting st170 brakes? (apart from loosing a finger nail!) they look nice how they fill the original wheel.
Old Feb 9, 2012 | 05:28 PM
Joe91's Avatar
Joe91
Yeah i wanted to do some of it myself though to keep me going through the cold days! It was sore haha!
Thanks, Joe
Old Feb 9, 2012 | 05:29 PM
Joe91's Avatar
Joe91
Alot of grinding on the caliper (only to fit under 15's) and some spacers, not sure exactly how big they were but ill find out for you when i get back to them, ill send you a pm.
Thanks, Joe
Old Feb 9, 2012 | 06:16 PM
P 17eed's Avatar
P 17eed
Brilliant, cheers
Old Feb 10, 2012 | 04:36 PM
Joe91's Avatar
Joe91
i took your advise maxwell, the rocker is in the spray shop now getting blasted and powdercoated satin black!
Old Feb 10, 2012 | 06:42 PM
rst-g's Avatar
rst-g
ZETEC TURBO
whats it drive like on the t34?? laggy?
Old Feb 10, 2012 | 08:31 PM
Rab's Avatar
Rab
Fucking superstar........
I was eating a biscuit when I got to the pics of your mashed fingers.
Old Feb 11, 2012 | 10:21 AM
Joe91's Avatar
Joe91
yeah it's laggy, but nothing like the feeling of it when is comes on boost, and the car was only running 180bhp, god knows what my new engine will be like!
haha sorry rab, apologies.
Thanks, Joe
Old Feb 11, 2012 | 03:09 PM
jonny s2's Avatar
jonny s2
Ouch bet the finger hurt.......
build will be interesting
Old Feb 11, 2012 | 03:33 PM
v man's Avatar
v man
Zee Germans are coming
should be all good with nms building the engine
but
why not get the head fully worked while its getting work done to it anyway
will save you having to take it off if you decide to go more power later
seems silly to go that way personally
Old Feb 11, 2012 | 11:54 PM
Joe91's Avatar
Joe91
Its all to do with expense v man, costing enough as it is, plus the head doesnt have loads of skimming life left in it so when i come to wanting more power, ill just buy a new one and start again..Sounds silly but i have a deadline and a budget so i didnt do it first time..
Thanks, Joe
Old Feb 13, 2012 | 07:43 PM
Joe91's Avatar
Joe91
Quick update, Rocker cover has been shotblasted and powdercoated satin black.
Old Feb 21, 2012 | 06:21 PM
Joe91's Avatar
Joe91
Big update..
Done a bit of work on the rocker cover, bit different and havnt seen it done before, i done it with a dremel and it took a while! Its the norris motorsport 'NMS' engraved into the cover..
Next up was to remove the driveshafts etc to remove the engine..it was dark outside so the picture quality is crap..
Then the struggle began with taking the engine out, bearing in mind this was done on a driveway with minimal tools!!
bonnet off..
And yes this was lifted out with a bar and strops :/
The final thing was the steering wheel and snap off boss arrived today..
Old Feb 21, 2012 | 08:41 PM
RAPID 3DR's Avatar
RAPID 3DR
karl is the man for the job.
whats that stuff you have used on the grinding sparks in the paint,i could do with some as my mate cut a bonnet up next to mine but said he did covered it up,yeah with some shite old curtens
my car is white so the bits of metal stand out alot,how does it work if you dont mind me asking?
cheers
Old Feb 21, 2012 | 09:41 PM
01dwilkinson's Avatar
01dwilkinson
Mk3 capri 3.0l
Will be mint when finished, That finger looks painfull. I once shut my capri door on mine and it fully closed. Had to open door to get it out.
Old Feb 21, 2012 | 10:05 PM
Maxwell's Avatar
Maxwell
Irregular Poster
The rocker cover came up an absolute treat mate!!!
Old Feb 22, 2012 | 07:20 AM
Stolton's Avatar
Stolton
Good looking project there mate.
Old Feb 22, 2012 | 06:28 PM
rstom95's Avatar
rstom95
mint project the engraving looks top dog on the rocker cover
Old Feb 22, 2012 | 08:05 PM
Joe91's Avatar
Joe91
cheers mate it took al long time!!
Joe
Old Feb 23, 2012 | 08:04 PM
Joe91's Avatar
Joe91
purchased some standard yellow side lights..
New hub and wheel bearing on..
I have a parcel to pick up tomorrow from the post office do will update what it is tomorrow.
Joe
Old Feb 25, 2012 | 05:01 PM
Joe91's Avatar
Joe91
Default Little update
Spent a solid 4 hours on the engine bay today, thought id try and tidy it before the car goes up to NMS next saturday..
Couple before, mid and after pictures, pretty chuffed with the results in little time.
Before, Looking tired and old!
Middle of the process, looks alot better but has lots of patches of lost paint like under the header tank and fuel filter..
After, all sprayed/cleaned up (roughly)
couple others..
before and after comparison..
Also i received my flocked bit of dash from tony turbo on here, well chuffed with it, all the switches for anti-lag/launch control etc etc
Old Feb 28, 2012 | 05:03 PM
Joe91's Avatar
Joe91
Default New parts arrived
Getting close now to taking the car up to NMS, Cant wait!
Got my vibra-technic engine and gearbox mounts through, decided to go for the competition ones just to be sure, some would say a bit ott for a everyday car but it will see its fair share of track days this year!
Also gave her the last wash before i take her 200 miles away to NMS.
Old Feb 28, 2012 | 11:38 PM
beaver rs 88
in the garage
Nice one mate gonna be a nice s2 when NMS have worked their magic, sweet job of the bay too looking fresh.
Old Feb 29, 2012 | 05:14 AM
Nice project.I nearly puked when i seen your finger blaaaa.
Old Feb 29, 2012 | 12:18 PM
*аиđяєа's Avatar
*аиđяєа
ɔɐᴘʈᴀᴉи ᴀᵴʙο
Firstly, OMG ouch! That must have been so painful!
Nice car, will be awesome when its all done. Great work on the engine bay, looks much cleaner and a clean bay is nicer to work in too
Old Feb 29, 2012 | 08:21 PM
Joe91's Avatar
Joe91
Thanks for the comments chaps!
Joe
Old Mar 1, 2012 | 06:59 PM
Joe91's Avatar
Joe91
Got my standard fuel cap through yesterday so swapped it for my chavvy one that came with the car..
Also fitted my steering wheel and boss today..
Thanks, Joe
Old Apr 12, 2012 | 05:02 PM
Joe91's Avatar
Joe91
Small update..I got the car up to Oli/Karl a while ago and im hoping to get the car back next week sometime as they have been soo busy! Then only real thing that has changed spec wise is a different turbo, we decided that my current turbo was nakered so ive brought a cossie 4x4 t3 for the time being so i can run the car in and save for my new NMS spec T34.
The car will be getting re shelled in october to a white shell that im buying which is ment to be very nice (yet to see it)..
Also ive been looking into gearboxes for a while now and have decided i cant afford to buy a cts stage 2+ and brake it, then buy another etc etc..So im going to be running a Mk2 Focus RS box in it when Oli/Karl give me the all clear to do the conversion!
Ive brought a couple little bits for the car since the last update, a new boost gauge being one..
And these clocks, Made by 'Twins' which im chuffed about!
Thanks, Joe
Old Apr 12, 2012 | 05:10 PM
Looking good ,whats up with your shell ,it looks mint in the pics
Old Apr 13, 2012 | 11:50 AM
Joe91's Avatar
Joe91
The pictures hide alot tbh, got a hole in the scuttle and a rusty passenger door, plus there's bubbles around the sunroof and boot etc, NMS are mot'ing it and have done loads of welding on rear chassis leg and sills..Just start fresh and have a decent looking and quick escort! The red shell is ok for this summer though to go round tracks etc, not to bothered.
Thanks, Joe
Old Apr 13, 2012 | 03:08 PM
0150carmac's Avatar
0150carmac
Looks like your going to have a good solid engine there to stick in your reshell
p.s finger looks sore ouch i remeber moting a old metro spun the back wheel to check wheel bearing got my fingers caught between tyre and sandwich plate ouch
Old Apr 20, 2012 | 03:35 PM
Joe91's Avatar
Joe91
So about time i did an update.
Heres a picture of the engine built after a long wait, Basically i was aiming to have the car back on the road for the first week in april but as always it wasnt straight forward, NMS where giving the car an MOT while its there and Oli came across ALOT of rust that needed sorting, so this has put it all back a couple weeks, hopefully it will pass the MOT mid next week and ill have it back soon!
Lots of pictures of rust/holes for those of you that get turned on by it, After these pictures you will understand why i am keeping this shell for summer track days and reshelling the car in october!
Anyway, porn pictures are here..Big thanks to Chris ST off here for taking them and sending them across.
I asked NMS to remove my abs etc at the same time, With that came a new master cylinder because mine was leaking and all new brake pipes.
Im also going to pick up my full flocked dash off Tony Turbo on sunday, As you might have noticed im buying lots of interior parts but no body parts, this is purely because i can put everything into the new shell in october.
Thanks, Joe
Old Apr 20, 2012 | 03:48 PM
jonny s2's Avatar
jonny s2
i have a nice solid bare metal repainted moostone blue shell 90 spec doing nothing if your interested in a re-shell
Old Apr 20, 2012 | 03:56 PM
Joe91's Avatar
Joe91
Id like to mate but im doing it in october due to funds, also the shell im getting has full 90 spec bodykit and loom, brakes etc and freshly painted, thanks for the offer though mate.
Joe
Old Apr 20, 2012 | 04:34 PM
jonny s2's Avatar
jonny s2
no worries the shell is getting built back up hopefully in a few months(fingers crossed)
bet you cant wait to have yours on road, are you taking it to any track days?
