Rocker cover gasket, whats best?
Old Jan 31, 2012 | 06:06 PM
WongRS's Avatar
WongRS
Default Rocker cover gasket, whats best?
I am fed up to the fooking back teeth of these things leaking.......
Is the cometic one the best on the market?
http://www.ebay.co.uk/itm/COMETIC-CO...item45fc672e8f
Like so, or is there better, i had one of those and it failed on the way to classic ford last year, which resulted in a quick reseal using some loctite sealant in the campsite saturday night, and then a screwed engine on the way home sunday when all the sealant went for a wonder round the oil ways.
The new engine is leaking now, so want to know whats best, i am having the cover machined tomorrow to make sure its 100% flat.
Old Jan 31, 2012 | 06:16 PM
Paul_RS's Avatar
Paul_RS
Used both cometic and standard, never had bother with either. I put a standard one on mine during my rebuild though, so i'd go with standard
Old Jan 31, 2012 | 10:35 PM
R5COS's Avatar
R5COS
As Paul said mate ive used both also i find the cometic one easier to line up but apart from that no issues with either
Old Feb 1, 2012 | 07:11 AM
WongRS's Avatar
WongRS
Ok, thanks chaps.
Old Feb 1, 2012 | 07:36 AM
RSGARETHW's Avatar
RSGARETHW
always working
Dan drop me a text please
Old Feb 1, 2012 | 08:41 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I always use a very light smear of sealant! The only way the sealant would get into your engine and block an oil way is if you use far to much! There is no problem at all with using sealer
Old Feb 1, 2012 | 09:52 AM
bad boy rs's Avatar
bad boy rs
Same as above small bit of sealer especially round half moons where it meets gasket
Old Feb 1, 2012 | 10:44 AM
Rsmat's Avatar
Rsmat
Gaskets-direct...
Old Feb 1, 2012 | 04:51 PM
Len's Avatar
Len
Always used the £17.50 one on eBay, they are the same as the cometic, nether had a problem with them & I've reused them a few times lol
Old Feb 1, 2012 | 08:12 PM
RSGARETHW's Avatar
RSGARETHW
always working
Originally Posted by rsmat
Gaskets-direct...
Yeah baby you know it
Old Feb 1, 2012 | 08:23 PM
martinembleton's Avatar
martinembleton
But which gasket as there is 3 on the gasket direct site
Old Feb 3, 2012 | 04:14 PM
3Door4x4GT30's Avatar
3Door4x4GT30
I think the cometic needs a bit of filing to fit perfect. I always remove front camshaft caps and seal under them first. Then put loads of silicone sealer on half moons as they don't always seal properly. Also could be breather issue so make sure this is not causing excessive pressure. Breath from both side of engine block and bin the flame trap. Cheers.
Old Feb 3, 2012 | 04:18 PM
Rsmat's Avatar
Rsmat
The Nbr ones from gaskets-direct are same material as cometic and fit perfect and are well cheaper... Never had a problem with mine.
Mark RS
Mar 5, 2021 06:08 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
deathrider666
Sep 28, 2015 06:12 PM
