sierra window problem
Old Jan 29, 2012 | 11:51 AM
CHUNKYS RS's Avatar
CHUNKYS RS
Default sierra window problem
my battery went flat on my saph and now the window one touch won't work ,ive tryed holding the switch closed and then open but stoll won't work any ideas
Old Jan 29, 2012 | 11:57 AM
Rax's Avatar
Rax
One touch windows on a sapphire ? its probably not broken,it dosnt have the function.
Old Jan 29, 2012 | 12:03 PM
CHUNKYS RS's Avatar
CHUNKYS RS
used to work before battery went flat now they just move about 2" at a time
Old Jan 29, 2012 | 12:18 PM
Rax's Avatar
Rax
Seriously I have been in hundreds of sierras and never seen one with this,I think the last one I drove was K or L reg and it didnt have it.I am genuinely confused now,is my memory that bad No I am 100% sure they dont have it,but yours did I am sure someone will be along shortly with another opinion
Old Jan 29, 2012 | 12:25 PM
CHUNKYS RS's Avatar
CHUNKYS RS
it is a late 92 if that makes any difference
Old Jan 29, 2012 | 12:28 PM
Rob Virgo's Avatar
Rob Virgo
Modern one touch systems need to be retaught the end stop limits, open window fully and close fully several times, turn off ign and then try again.
Usuall fix
Old Jan 29, 2012 | 12:54 PM
charlie luciano's Avatar
charlie luciano
I have one touch windows on my car (only the fronts) but its a feature of the alarm 'smart windows' I don't think any saph came with one touch windows irrespective of year
Luciano
Old Jan 29, 2012 | 01:15 PM
CHUNKYS RS's Avatar
CHUNKYS RS
maybe thats it i have a toad fitted so that might give me the one touch option then
Old Jan 29, 2012 | 01:17 PM
charlie luciano
It could possibly be an option with that alarm
Luciano
Old Jan 29, 2012 | 01:18 PM
cossiestu's Avatar
cossiestu
I've had the problem of them stopping an starting, but that was the switch..
Old Jan 29, 2012 | 02:16 PM
martysmartie's Avatar
martysmartie
As said they never had such a feature, if you have then it would be part of an aftermarket alarm system, that needs to learn when the window is fully down and up.
The way to enter the alarm will "Learn" will be specific to your alarm.
Martin
Old Jan 29, 2012 | 03:43 PM
Eigdoog's Avatar
Eigdoog
ą§~Quadzackular~§ą
Im sure i got told you can make them one touch with a relay, pretty easy to do as well so ive been told.
Old Jan 29, 2012 | 04:16 PM
martysmartie
Correct.
Martin
3dr cossie
11
Dec 21, 2015 03:38 PM
andyrs1600i
Aug 30, 2015 07:21 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
