300mm rear brake conversion on the saph done ;)
well chuffed today,i did a 300mm rear brake conversion on the saph and i must say works a treat,realy good
i used
new cossy 4x4 rear calipers 200 quid
st170 front discs (skimmed to 22mm) 46 quid
stright brakets from hispec 70 quid
and 14mm spacers to go on the brakets
well chuffed awsome brakes
so a cheap 300mm setup if i didnt get the new calipers
but i needed them anyway as the ones i had were knackerd
i used
I'm sure matt baxter off here mentioned that he'd used st170 fronts on the rear of his but didn't say anything about skimming them to 22mm i take it the disk wont fit in the 4x4 caliper un skimmed?
no they wont the discs are too wide for the calper
track.focus'd
Aug 12, 2015 05:53 PM
