can a cosworth water pump be rebuilt
Old Jan 28, 2012 | 02:37 PM
damien roe's Avatar
damien roe
Default can a cosworth water pump be rebuilt
as above can a cosworth water pump be rebuit it's a rs500 pump so not to say i can just buy a new one
even if i had to buy a new 2wd or 4x4 pump to take the bit's out of i wouldn't mind
thanks for your help
Old Jan 28, 2012 | 02:59 PM
adam151082's Avatar
adam151082
is there a difference in the 500 to the normal 3dr pump?
Old Jan 28, 2012 | 03:07 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
i beleive so. The housing is different i know for a fact. Perhaps a 3dr one will fit but its then not origional. Im sure ford changed for a reason. Maybe it has more/less bolt holes to bolt to the block etc? Paul at nyrs will know for sure aswell as a few other folks
Just found this link for you
http://www.rsownersclub.co.uk/rsocbb...d.php?t=136934
Old Jan 28, 2012 | 03:09 PM
damien roe's Avatar
damien roe
it's the pipe leaving the top of of the 500 pump lines up perfect with the 500 thermostat houseing where a differant pump won't line up as good
Old Jan 28, 2012 | 03:12 PM
BRAMMER's Avatar
BRAMMER
Why a 500 pump damo - could you not just run a 4x4 pump as they must be of equal flow if not better than a 500 item
Old Jan 28, 2012 | 03:17 PM
botters's Avatar
botters
competant bodger
i thought 4x4 and 500 pumps were the same? if not mk motorsport makes billet rebuildable pumps
Old Jan 28, 2012 | 03:19 PM
damien roe's Avatar
damien roe
which is better chris??
if need be i will get a silicone hose made to mate the 500 thermostate to the 4x4 pump if rouse will do one for me
Old Jan 28, 2012 | 03:20 PM
damien roe's Avatar
damien roe
never thought of that thanks mate
Old Jan 28, 2012 | 11:32 PM
damien roe's Avatar
damien roe
bump
Old Jan 29, 2012 | 02:55 AM
Paul_RS's Avatar
Paul_RS
Just use a 4x4 pump?
Old Jan 29, 2012 | 02:09 PM
damien roe's Avatar
damien roe
the hose joining a 500 thermostat to the 4x4 pump won't be bang on line but the way thing's are looking i'll get rouse make me a hose to fit 100%
Adam-M
Aug 26, 2015 05:53 PM
cameron2
Aug 25, 2015 07:18 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
ekjim
Aug 17, 2015 08:57 PM
Aug 14, 2015 07:29 AM
