help junking my sky router and using a normal one
Old Jan 28, 2012 | 01:31 PM
rsturbolee's Avatar
rsturbolee
Default help junking my sky router and using a normal one
i found a link on the net entering my mac address from the sticker of bottom of router they gave me this info
Sky router password generator
username
password
default wpa network key :
i believe this info then somehow can let me use a normal router???? my router is 5 years old it constantly looses internet and my speedtest result just now was 0.4meg pmsl
so what one can i go buy from pc world and how do i do it>?
Old Jan 28, 2012 | 02:05 PM
kjc300's Avatar
kjc300
username
password
You can do it. But delete your info off here - NOT a good idea posting it up!!
Old Jan 28, 2012 | 02:21 PM
Eagle's Avatar
Eagle
Super Moderator
the username and password should allow the router to work with sky..
you should be able to install a normal one and it "should" work ok... would phone sky if it doesnt as i have no idea if sky tie in the mac addy's or not
Old Jan 28, 2012 | 03:34 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
There is one page of vital information that Sky deliberately hides from the setup pages on their routers. These details are needed for another router to work. Apparently you can get the necessary information from some of the user forums. Easiest thing is to get another Sky router. PM me as I can help.
Old Jan 28, 2012 | 03:42 PM
martysmartie's Avatar
martysmartie
The username and password are just the login credentials for the router along with the DEFAULT WPA key, it's not personal information, and it is totally irrelevant to you using another router!
Ideally you should change both of these!
You need the actual config from the router, i.e. connection settings, credentials, most of this is easy nowadays as all this sort of stuff is "Wizard guided on a CD which your new router should have"
I very much doubt it's the router causing your problem, they don't just "degrade" overtime, you may have another underlying problem, it's worth updating your firmware if you can.
Also are you using an Ethernet or wireless connection?
The MAC (Media Access Control) address is just a unique hard code which every networking device has, which is a crucial part in networks!
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
dojj
Sep 19, 2015 10:11 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
bigryrs
Sep 7, 2015 06:45 PM
