Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
New Owner - EML query
Old Jan 27, 2012 | 08:07 AM
Blue Lagoon's Avatar
Blue Lagoon
Default New Owner - EML query
Hello all, I am a new owner of a 1.6 ford focus 2002. I have a query that I am hoping someone knowledgable will be able to help me with...
On start up of the car, the engine management light flickers for 30 secs - 1 min. It doesnt come on, just a feint flicker. It then stops flickering and doesnt come back on all journey. The car idles a little low, but other than this it runs really well with no noticeable problems. There are a few niggly things with the car such as the wiper relay/fuse needs replacing and the exhaust sounds a bit raspy so thinking a leak ( the last mot gave an advisory of some corrosion to part of the system) so could these be causing the flickering?
We have had a fault code reader plugged in and there are no codes coming back
It doesnt happen on every start up... If we turn the engine off for 10 mins and start it again (ie. not a cold start) it doesnt happen. It only seems to happen from a cold start
Any ideas would be greatly appreciated
Old Jan 27, 2012 | 08:29 AM
oldford's Avatar
oldford
Did you try activating the EML with the scanner?
Or tried to create a fault that would set the EML on?
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
rsguy
44
Sep 29, 2015 03:29 PM
Mc5506
Sep 29, 2015 09:06 AM
