Cossie owners running BIG boost???
big floppy donkey dick
you tried this yet?
if not you probebly will
http://www.ebay.co.uk/itm/Ford-Sierr...item35b3f0ea27
sorry
but coundnt resist
p.s who`s the 2 idiots thats bought it???
SERIOUSLEY???!!!
sorry
but coundnt resist
SERIOUSLEY???!!!
Don't know about that but "K-seal" for example can do a good job, albeit it may not in a FI engine.
But yes quite why they have applied to the name to the car is probably an attempt to claim "Cosworth tax", also I don't quite see where the engine size comes into it.
Martin
Martin
Martin
I heard it repairs piston rings and crowns. And reprofiles the crank and repairs big end shells.
I also heard a voodoo shaman preist blessed every bottle from factory.
£29.99 bit on the expensive side as I can buy silicon gasket sealer for less than that and it would hold better.
If you want to pour things in your header tank for that miracle engine cure, try pissing In it as the iron that's in your body comes out your hose into your engine and welds all the little molecules of iron together to patch your cracked 200 block
CabrioTurbo
Aug 1, 2015 11:04 AM
