rs2000 rev counter
Old Jan 26, 2012 | 06:35 PM
maido's Avatar
maido
Default rs2000 rev counter
hi ive got an rs2000 in my mk4 cab.. only problem is my rev counter if i drive normal its fine if i accelerate hard it bounces about all over. ive bein told it needs some sort of resistor any ideas?
Old Jan 26, 2012 | 07:01 PM
Icurus's Avatar
Icurus
What tacho do you have? the mk4 cab one?
Are you using the EDIS4 module to run the ignition?
Old Jan 26, 2012 | 07:03 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
you need EFi CVH clocks
Old Jan 26, 2012 | 07:12 PM
maido's Avatar
maido
mk4 clocks then everything else from donor car.. ive tried mfi which didnt work its now got efi ones in which bounce about
TPM961
Jan 15, 2018 10:50 AM
Fordmad!
15
Sep 27, 2015 06:24 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
cozzy jeff
Aug 14, 2015 05:46 PM
