does a 1997 evo 4 need a cat
Old Jan 25, 2012 | 10:10 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default does a 1997 evo 4 need a cat
car was imported in 2006
cheers
Old Jan 25, 2012 | 10:11 PM
Oranoco's Avatar
Oranoco
It's an import so it should be emmissions tested to pre 92 regs
Old Jan 25, 2012 | 10:12 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
yes, any car april 1992 on by law needs cat......... regardless of nothing am afraid
Old Jan 25, 2012 | 10:21 PM
Cossie Sean
really Oranoco?
i was always thaught otherwise.
what about new VOSA regs then, any car supposed to have cat (any year) must have one fitted and working
interesting this as i had a lot of trouble after an imported civic had a K20 turbo conversion with no car (1996 saloon/coupe thing), we failed it on emissions and no car, lad went to VOSA and he had to leave his car with vosa, we we advised we were right and he had to fit a cat,
im aware that fitting older engine in car, it was only engine year that was applicable, i.e like my A4, 1999 car but runs 1991 2.2 20v Turbo 5 pot and needs no cats.
interesting thread!
Info from Stevie Turbo, anything here you can shed light on?
Sean.
Old Jan 25, 2012 | 10:32 PM
Oranoco's Avatar
Oranoco
That's always been my understanding on the subject, and am sure that's what I found reading through some of the manuals. I was asked to do some digging for a friend who'd been told the same when he got his 93 WRX. The information I found on this was backed up by another user on here at the time
Engine swaps the need for a cat is governed by whichever is the older of the 2, car body or engine. For example putting a Zetec engine in a Mk2 Fiesta you would not need a CAT. Put a Cossie engine into a Focus and again you won't need a CAT. Put a Focus ST170 engine into a Mk6 Escort and you would need a CAT
Old Jan 25, 2012 | 10:46 PM
Cossie Sean
Every impreza we sent for a test, and GC8`s were my only car i worked on besides Evo g/boxes and clutches all day every day, failed on no cats, import or not
we tried the import 10 digit chassis number every time and got bitch slapped with emissions fail
grey imports are a grey area LOL
Old Jan 25, 2012 | 10:48 PM
The Youth.'s Avatar
The Youth.
My escort is an import and is declared manufactured in 1995 my MOT clearly states cat test not required!!
steve
Old Jan 25, 2012 | 10:55 PM
Cossie Sean
fuckin ell, we were robbed of so many tests!
guess we should have looked into it before bolting STD cats/systems to every GC8 that went for test.................DOH!!
Old Jan 26, 2012 | 06:05 AM
Robs Frst's Avatar
Robs Frst
Yep will need a cat for MOT.
Old Jan 26, 2012 | 06:38 AM
rog's Avatar
rog
Correct me if I am wrong but there appears to be confusion here, as far as I am aware there is not any specific requirement on an MOT that the car HAS to have a cat, only that it must pass the emissions test levels that woud be applicable IF it came with a cat in the first place.
i.e late spec cos with cat removed, passes an emissions test=legal MOT
I did hear of talk that they were going to change the regs so that it specified there had to be a cat fitted, but I thought that was all hear say???
Old Jan 26, 2012 | 10:43 AM
focusv8's Avatar
focusv8
Info removed following post below
Old Jan 26, 2012 | 11:13 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
It would be best to use the latest info, rather than the stuff above seeing as the test was 'amended' for 2012.
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
richierich1986
Sep 18, 2015 03:29 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
