Hart TB Bracket, poor fitment (moded bracket fitted)
Old Jan 23, 2012 | 09:25 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Hart TB Bracket, poor fitment (moded bracket fitted)
What are people's thoughts on the way the cable is when on full throttle ?
Not very happy with the way it is
Steve
Old Jan 23, 2012 | 09:26 PM
Rsmat's Avatar
Rsmat
One word.... Airtec..!
Old Jan 23, 2012 | 09:28 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
But the Airtec bracket is for a 2wd and 4x4 TB, not a ST Escos TB
Steve
Old Jan 23, 2012 | 09:29 PM
Less.'s Avatar
Less.
having a mid life crisis
Dont know about TB's etc but that does not look very good?
Old Jan 23, 2012 | 09:32 PM
Rsmat's Avatar
Rsmat
Steve
Yes true mate... Doesn't look to clever tho mate...
Old Jan 23, 2012 | 09:33 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
same as mine as i said the cable runs at to much of an angle the square needs to be up higher im going to get mine modded i think as i dont wont my cable snapping! it still gets the full range of movement and dosent feel tight but im still not that happy with it iver!
Old Jan 23, 2012 | 09:45 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
But we shouldn't have too
As said it does work, and smoothly but im also worried about the cable snapping.
Steve
Old Jan 23, 2012 | 09:46 PM
saph4be's Avatar
saph4be
Not sure need another pic!
Old Jan 23, 2012 | 09:47 PM
whizzisat114's Avatar
whizzisat114
Dont look a very fIt good for the money they are
Old Jan 23, 2012 | 09:49 PM
ajamesc's Avatar
ajamesc
i no we shouldent but after the time it took to even get that one lol id rather just take mine to andy robinsons and get it done the same day! if we had stainless wire at work id do it my self
Old Jan 23, 2012 | 09:50 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I know a man that can as well, it will just make it a bloody expensive bracket
Steve
Old Jan 24, 2012 | 04:53 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Anybody else got any thoughts on the way it operates or am i just being picky ?
Steve
Old Jan 24, 2012 | 05:02 PM
focus 4x4's Avatar
focus 4x4
Mine fitted perfectly no problems whatsoever - ill dig some pictures out
Old Jan 24, 2012 | 05:06 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Are you using a ST Escos TB ?
Steve
Old Jan 24, 2012 | 05:08 PM
focus 4x4's Avatar
focus 4x4
yeah i found a brand spanker 2wd tb so im using that , ive since binned the hart inlet and now using a ST escos inlet with the 2wd TB.
Old Jan 24, 2012 | 05:11 PM
focus 4x4's Avatar
focus 4x4
All i did was move the P/S slightly reservoir towards the front of the car . no one even noticed !!
Old Jan 24, 2012 | 05:13 PM
ajamesc's Avatar
ajamesc
thats a different throttle body and different cable mount!
Old Jan 24, 2012 | 05:14 PM
RONNIE AMIS's Avatar
RONNIE AMIS
Funny that because that's a hart inlet. What make is the bracket? Not airtec
Old Jan 24, 2012 | 05:15 PM
focus 4x4's Avatar
focus 4x4
nah its a proper hart bracket ,
This bracket was designed with the hart inlet for the hart inlet , hence why it fits properly.
Old Jan 24, 2012 | 05:16 PM
ajamesc's Avatar
ajamesc
what on earth has who cast the manifold got to do with a throttle cable bracket made by a 3rd party?
Old Jan 24, 2012 | 05:19 PM
RONNIE AMIS
I'm stating that it's not a Airtec inlet or bracket as rsmat stated. And I asked who made the bracket
Old Jan 24, 2012 | 05:21 PM
focus 4x4's Avatar
focus 4x4
dunno mate , i got mine from the caster! the proper kit should look like this.........
Old Jan 24, 2012 | 05:26 PM
ajamesc's Avatar
ajamesc
There made by a fabricator that blue sprint use who i think is near too there work shop mate there is only a problem as not many have been used with the small turbo throttle body when i ordered my manifold only one other had been ordered that way by m.a.d and they sorted the cable bracket them selfs
Old Jan 24, 2012 | 05:48 PM
grcossie's Avatar
grcossie
What`s the reason for you not using the hart one?
Old Jan 24, 2012 | 05:55 PM
Deano's Avatar
Deano
Ronnie I think Mat was implying that the Airtec Plenum wouldnt have this issue , at least thats how Ive read it
Old Jan 24, 2012 | 06:06 PM
focus 4x4's Avatar
focus 4x4
Not reponsive enough for my engine spec.
Old Jan 24, 2012 | 06:08 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Which is ?
And what do you use it for ?
Steve
Old Jan 24, 2012 | 06:17 PM
ajamesc's Avatar
ajamesc
but its meant to be the best flowing inlet out there
Old Jan 24, 2012 | 06:24 PM
Rsmat's Avatar
Rsmat
I know... It's a standing joke with Steve... Hence should have had a airtec...
I know the brackets 3rd party as well ..
Old Jan 24, 2012 | 06:27 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
i cant see what the fuss is about steve
your car aint seen that much throttle ever !!!!!
lol
Old Jan 24, 2012 | 06:41 PM
focus 4x4's Avatar
focus 4x4
It probably is the best when youre seeing figures of 650hp plus , but the hart inlet isnt as responsive as a st esc inlet for 500hp applications , hence why i swapped .
Old Jan 24, 2012 | 06:43 PM
ajamesc's Avatar
ajamesc
not what i was told thats why i sold my st esc one and got a hart one
Old Jan 24, 2012 | 06:48 PM
-beefy-'s Avatar
-beefy-
i got told the hart plenum was fully approved by chuck norris
and if chuck norris approves it then you know its the truth !!!
Old Jan 24, 2012 | 06:52 PM
ajamesc's Avatar
ajamesc
cool well chufed with that i may even have has autograph air brushed on now i no that!
Old Jan 24, 2012 | 06:59 PM
focus 4x4's Avatar
focus 4x4
Old Jan 24, 2012 | 07:16 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
There is a difference between flow capability and throttle response. Just because a plenum has the volume to not become a restriction in producing power it does not mean that the throttle response is not compromised. Swedish plenums used to be noticeably less responsive at lower engine speeds but would make more power at the top end of the rev range. There are very few modifications that can be performed to engines that will provide a global gain without there being some form of compromise.
Old Jan 24, 2012 | 08:34 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
lol
I have to think of my MPG
Steve
Old Jan 24, 2012 | 08:51 PM
RONNIE AMIS
my apologies
Old Jan 25, 2012 | 09:16 AM
ajamesc's Avatar
ajamesc
I guess everyone has different opinions mine has a 500bhp set up and before i ordered mine i asked the person who maps mine if i would benefit from a hart over my st esc inlet and was told yes
Old Jan 25, 2012 | 04:12 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
In the booklet that comes with a Hart, a dyno seesion showed a engine that made 378bhp on a std TB and std inlet made 411bhp on the Hart but lost power upto 4500rpm
Steve
