any BMW techs on??
i have an e60 520d and last night it wouldnt start, lights wouldnt come on etc,
i pulled a few fuses and left it and it started,
this morning it started, drove a while, got home and it wouldnt start, AGAIN
tried everything, had over 12 volts at the battery, alternator, starter etc and wouldnt start, doesnt even try to turn over
had a mate come round with his car and tried to jump start as by this point a low battery warning came up on the idrive
anyway still wouldnt go, went to remove the battery ant noticed about 3" of water in the battery well,
i removed the neg terminal and left it 10 mins and it started again!
i should point out i have daylight running lights and it does around 3000 miles per year and iv had it 2, does this sound like a battery problem or something else?
the battery is off the car now and on charge untill tomorrow night,
i know pal my mate that came round is a ford tech and didnt no the problem, the battery has test hole that says it isnt charged properly so im giving it a full charge to see, it doesnt do the miles so may not be charging properly, at first i thought it could be the switch on the clutch so the start button works but that seems fine, i guess i will see after a full charge if it still happens or if it reboots after having the battery removed
i dont mate, i will have one on my mk2 escort im building,
battery has been charged over night, just fitted and started with no error codes so shouldnt need plugging in, will wait and see as i dont think the battery i charged as much as it should be
well iv charged the battery and will see how it goes, if its still ok in a wek or so i will check the standing voltage every week and see if its holding charge
