Compression Test
Old Jan 22, 2012 | 11:54 AM
Jasoncmor's Avatar
Jasoncmor
Default Compression Test
Hi all.
Im thinking about buying a compression tester, only a cheap bit of kit @ £13, It say's that when you have connected the tested to crank the engine, Firstly, I'm assuming that means to start the engine, and then second, it worries me that only 3 of the cylinders would be firing, Will it damage my engine if I did that?
Cheers, Jason
Old Jan 22, 2012 | 12:01 PM
JamesH's Avatar
JamesH
Get it warm, then remove all 4 leads and plugs. Put the compression tester in 1 cylinder at a time. Crank for 5s or so, the engine will only reach cranking speeds as nothing will be firing
Old Jan 22, 2012 | 12:03 PM
Jasoncmor's Avatar
Jasoncmor
Thanks for that
Old Jan 22, 2012 | 12:08 PM
Jasoncmor's Avatar
Jasoncmor
Just one other thing, I've read the in general, engines have 140 - 160lbs of compression with no more than a 10% difference.
Is that correct, and for a 1.25 Zetec?
Thanks again.
Old Jan 22, 2012 | 03:17 PM
JamesH's Avatar
JamesH
Sounds about right mate, main thing is that they're not far off each other
Old Jan 22, 2012 | 05:40 PM
stevieturbo's Avatar
stevieturbo
C**t
http://www.pumaracing.co.uk/comp.htm
Old Jan 22, 2012 | 06:47 PM
Brendan's Avatar
Brendan
struggling with reality
thanks for the info too!
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
