Welding onto cossie cam cover?
Old Jan 21, 2012 | 03:49 PM
rog's Avatar
rog
Default Welding onto cossie cam cover?
Need to weld a breather takeoff to the back of the cam cover, I have no idea about what its made of and what type of welding to use on it, also I think maybe th takeoff pipe is made of aluminium???
Old Jan 21, 2012 | 03:53 PM
Isaac.Hunt's Avatar
Isaac.Hunt
It's made from Aluminium, so best to TiG weld it if you can, if not resort to a MIG welder.
Old Jan 21, 2012 | 03:59 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Tig it, be careful though as it generates uber amounts of heat.
Old Jan 21, 2012 | 04:46 PM
nellyscossy's Avatar
nellyscossy
you dont normaly weld them you simply drill a hole and seal a tube into the hole then fix with a self tapper if needed at the back of the cover
Old Jan 21, 2012 | 05:14 PM
wattie's Avatar
wattie
I got mines tig welded on at a place in hatton, the breather kit i got came with the bit of pipe and the guynwelded it on for me, George Andrew in Dyce or any welders should have the equipment to do it, kinda spoilt for choice for stuff like that in Aberdeen,
Old Jan 21, 2012 | 05:40 PM
BRAMMER's Avatar
BRAMMER
I had a fitting made that was smacked tight into a hole in the cam cover but was threaded with 3/8NPT so a JIC fitting could be added for my breather kit
dombanks
Sep 21, 2015 08:38 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
Thanasis
Sep 7, 2015 07:33 PM
rog
Sep 4, 2015 07:24 AM
