Switched to a T4, what else do I need to do? (UPDATE-Gearbox has shat itself)
Old Jan 20, 2012 | 08:17 AM
rog's Avatar
rog
Default Switched to a T4, what else do I need to do? (UPDATE-Gearbox has shat itself)
Ok I've finally bit the bullet and bought a T4, something I've always wanted to try so I hope it's not a dissapointment
Basically i have a good spec stage 3 4x4 saph, which has standard internals and so far i dont plan to meddle with that too much until I have it all up and running.
From what I have read on here to fit this turbo I will need the following;
This is my recipe ** things I dont have yet.
T4 turbo
Alternator drop braket
2WD manifold
Turbo hanger thingee**
Bigger hoses for the T4**
Siemens 83 fuel injectors
Air injectors**
Modified exhaust downpipe with lambda boss for closed loop**
RS 500 cooler
Grp A headgasket
Alloy Radiator
Breather system
3 bar
Grp A pump with new loom and full aeroquip
Swirl pot and all the shiney nonsense
New fan loom
Chip of some description?**
From doing some research and calling MSD (James) I was advised and explained the benefits of running air injectors with this setup, something which I had overlooked and now almost fully ubderstand why, I would be alot more comfortable doing it this way after reading more about it last night.
So my next quaestion is, what have I forgotten???
Old Jan 20, 2012 | 08:31 AM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
Fresh undies , brakes and tyres in a1 condition ???
Amazed how many folk hump up the power and don't consider there tyres and brakes ......
That not a pop at u rog just in general
Old Jan 20, 2012 | 08:36 AM
rog's Avatar
rog
Yeah it's all covered mate, I see your point though, it's easy to not look past the engine sometimes! It has a reconditioned set of AP's on it and new tyres so we're all good there!
I think the only thing I have missed that I''m aware of is the transmission, but that's a work in progress.
Old Jan 20, 2012 | 08:39 AM
Rsmat's Avatar
Rsmat
Wasted spark I would have on that list.
Old Jan 20, 2012 | 08:41 AM
James @ M Developments.'s Avatar
What Clutch are you using?
May also be worth thinking about a set of uprated engine mounts.
Old Jan 20, 2012 | 09:35 AM
rog's Avatar
rog
Ok I will look into the wasted spark gear, it has the usual grp A coil on it justnow, already has the engine mounts done not long ago (vibratechnics) and clutch wise, I stuck in an uprated one but I cant remember which one, it's not a paddle though, I think it's just some AP organic plate with std cover.
Old Jan 20, 2012 | 10:19 AM
JamesH's Avatar
JamesH
I was told you'd be pushing an organic one to handle 480-500hp, so you may be ok, not sure what power you're aiming for?
Old Jan 20, 2012 | 10:24 AM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
I just skim read this thread so apologies if i've missed them, and i'm sure they've been mentioned, but put a set of fuel injectors on that list
For what its worth, i'm running 22psi held with Siemens 55s on my RS500 (standard engine) and I did that with Stu driving and me mapping - it's a really nice drive. Obviously the T4 is somewhat 'dead' below 4000rpm but the punch of power delivery puts a grin on your face!
Old Jan 20, 2012 | 10:28 AM
rog's Avatar
rog
Doh, yeah I bought a set of 55's from MSD earlier in the week. I'll edit it now.
Regards power delivery that sounds exactky what i am after so I'm really looking forward to getting everything assembled!
Old Jan 20, 2012 | 10:31 AM
DAN400's Avatar
DAN400
i would nt say you need an Alloy Radiator, as long as your std one is in good condition
Old Jan 20, 2012 | 11:16 AM
R4N SS's Avatar
R4N SS
arent 55s a bit small for the T4?
Old Jan 20, 2012 | 11:30 AM
JamesH's Avatar
JamesH
I think it's run on fairly low boost Ran
Old Jan 20, 2012 | 11:33 AM
v man's Avatar
v man
Zee Germans are coming
a new engine for when it all goes wrong
Old Jan 20, 2012 | 11:54 AM
wes's Avatar
wes
If you have a 4x4 head i would buy a Spec-R Rs500 turbo damper adapter, this then allows you to use an RS500 turbo damper.
You'll also need to file a lug off of the head, it is located above Cylinder 1 exhaust port just beloe the cam cover, the turbo will foul this otherwise.
Also when you fit the alternator drop bracket you'll need to cut a lug off of the block, you can't miss it
Old Jan 20, 2012 | 12:05 PM
Sticky.'s Avatar
Sticky.
What gearbox & diff are you using Rog?
Old Jan 20, 2012 | 01:06 PM
rog's Avatar
rog
Standard at the moment, but I'm under no illusions in that department.
Wes, much appreciated for the input mate, the more homework I do now the easier it will be for putting it all together!
Rgds the injectors, no they will be fine.
Old Jan 20, 2012 | 06:20 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Rwd for some proper fun
Steve
Old Jan 20, 2012 | 07:00 PM
botters's Avatar
botters
competant bodger
new underpants
Old Jan 20, 2012 | 07:02 PM
Rsmat's Avatar
Rsmat
And why would it go wrong when it's getting mapped properly....? Edit not fucking worth it..!
Old Jan 20, 2012 | 09:32 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
A book to read whilst it winds up and comes on boost?
I wouldn't get a T4 unless it had a roller bearing core!
Old Jan 20, 2012 | 09:38 PM
damien roe's Avatar
damien roe
guy's what power can it run on a standard engine
Old Jan 20, 2012 | 10:31 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
You forgot coming over to mine as soon as you've got it fitted and taking me for a blast
Old Jan 21, 2012 | 11:03 AM
v man's Avatar
v man
whats not fucking worth it mathew
Moonstone Steve.
You need my cam cover m8, look in for sale section, it has the alloy part welded on the side to bolt a RS500 horseshoe damper on it.
Steve
Old Jan 21, 2012 | 11:59 AM
wattie's Avatar
wattie
Out of curiosity, would a 2wd engine stand up to the same mods if done proper like this?
Old Jan 21, 2012 | 12:05 PM
Rsmat's Avatar
Rsmat
Writing a fucking essay on my iPhone.... And less of the Mathew it's my pet hate.
Old Jan 22, 2012 | 09:57 AM
ossie cossie's Avatar
ossie cossie
Would this be the same for the 4X4 engine in the escos?
Old Jan 22, 2012 | 10:08 AM
waynev1979's Avatar
waynev1979
was you bullied at school....you seem an angry little man. i am here if you need to talk
Old Jan 22, 2012 | 10:13 AM
v man's Avatar
v man
lol at the pet hate
Old Jan 22, 2012 | 11:25 AM
Rsmat's Avatar
Rsmat
Little no...!.... No I wasn't angry I was stuck under a 205 doing my sump gasket... Started to write and the stupid auto spell bollocks wrote all sorts so I just wrote the above....
Old Jan 22, 2012 | 01:30 PM
Turbosimpsons's Avatar
Turbosimpsons
Do some research on mappers. See which mappers get the results. Some mappers don't seem to be able to get proper results. You'll find tony@ Turbosystems gets probably the best results.
Old Jan 22, 2012 | 02:30 PM
JamesH's Avatar
JamesH
Agreed!
Old Jan 22, 2012 | 08:05 PM
wes's Avatar
wes
Agreed!
Old Jan 23, 2012 | 11:01 AM
rog's Avatar
rog
Nicely edited!
I'll give him a phone too, already spoken to a couple of tuners, just amassing the parts right now, I'm sitting typing this in terminal 5 waiting for a flight to Dubai so I hope to have all or most of the bits waiting for me by the time I get back to the UK in feb.
Old Jan 23, 2012 | 02:59 PM
DAN-Saff's Avatar
DAN-Saff
100% agree
Old Jan 29, 2012 | 01:50 PM
rog's Avatar
rog
Still doing research, even got told by one tuner not to stick this turbo on my setup....pah its bought and its going on!
Anyway Ive got the new turbo but its not 100% complete, the oil feed connection is mssing and i need to buy a new one, dont want grubby old shit on it, but can someone tell me if its the same thread as a T4?
http://www.ebay.co.uk/itm/Escort-Rs-Turbo-inc-Cosworth-T3-Oil-Feed-Turbo-Union-/140445678579?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item20b336fbf3
Also, I'm running a 2WD manifold onto 4x4 engine with 4x4 sump, will i need this part to because the manifold is in different place?
http://www.ebay.co.uk/itm/Sierra-RS-Cosworth-2wd-Turbo-Oil-Return-Pipe-/120851481190?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item1c234f4266
Assistance appreciated.
Old Jan 30, 2012 | 02:02 PM
DAN-Saff's Avatar
DAN-Saff
The std union has restricted flow but I don't think that one in the top link has that looks like a joiner from Pirtec. I think it's 1/8npt one side and 1/4bsp the other.
The 2wd oil drain pipe will fit nicer than the 4x4 but it is possible to use the one you have.
Old Jan 31, 2012 | 08:16 PM
rstoughy's Avatar
rstoughy
Rog,
Think I still have a 500 intercooler stashed away someplace if you need one.
Cant see me ever needing it again.
Old Feb 1, 2012 | 03:26 AM
rog's Avatar
rog
Cheers Dan, Ive got all those bits already then.
Toughy, got one already thanks mate. I might know a man locally who's after one, I will ask.
I'm still away justnow, nit sure when I am getting home but need to order the following parts to complete the build, may aswell do that via ebay so it's all there for when I get back.
Turbo hanger thingee**Finally found good priced one, bugger paying 190 for one
Bigger hoses for the T4** Not sure on my intercooler piping size as will have to measure
Air injectors**There seems to be only one vendo, still looking
Modified exhaust downpipe with lambda boss for closed loop**Will DIY this
Chip of some description**Looking like MSD
Old Mar 1, 2012 | 01:35 PM
rog's Avatar
rog
Ok here's an update, after almost completing the upgrade i realise that the turbo cost was only a small part of it.... food for thought.
915 -T4 turbo
XX-Alternator drop braket-NOT REQUIRED
30-2WD manifold
150-Turbo hanger thingee
110-Bigger hoses for the T4
185-Siemens 83 fuel injectors (still waiting for these from Fiveomotorsport in the US)
XXX-Air injectors (looks like I wont be running them now)
60-Fuel pump loom
50-New fan loom
220-Stack AFR guage
75-Cone filter
75-Gaskets and bolts
XXX-Chip/Setup
80-refurbed cam cover
15-Lambda bosses for downpipe
20-Longer oil feed pipe from head to turbo
XX-Random bent black hose from a 51 plate fiesta for free (from stat to the water pipe for heater matrix.)
Thats a tidy 1985 without a chip, I made a list before hand that approximated at 1500, how wrong was I, sure it'll be worth it though.
Now it's off to worry about the box and a hyd clutch conversion.
