how do you remove snapped bolts???
was undoing the exhaust bracket under the golf vr6 today and some of the 13mm bolt heads just snapped straight off! how do i get the rest of it out?
anyone got any links to tools i can buy?? helicoil or something
I have a few ideas... first of all try "rost off crafty" from wurth, this is a realy good freeing agent to get out rusted in bolts etc, then a stud remover. Sykes picavant make a good one, it rescued one of my wifes calipers once.
Then you can use a very thin diamond tipped cutting disk on a dremmel to cut a slot into the offending bolt etc and try a screwdriver.
The last and very very dificult is to drill it out so carefully you are then able to peal the thread out of the hole leaving the other thread intact. I have not been able to do this my self and only ever met 1 person who has done that succesfully.
hope this is a good start!
On a tangent
Remove everything you can so that the bit you are trying to undo will be out of the way
£20 halfords stud remover set has done every single stud I've ever encountered if I can get to it
Fudgey
Sep 17, 2015 01:06 PM
