Air Filter Relocation
Old Jan 18, 2012 | 04:38 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Air Filter Relocation
Whats people's view on this and is it worth doing ?????
Sorry for nicking your picture Ronnie
Steve
Old Jan 18, 2012 | 04:40 PM
lukeytheduke's Avatar
lukeytheduke
looks amazing! Would it work as well with the grill in front of it though??
Old Jan 18, 2012 | 04:42 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Its a lot better than being stuck behind a headlight lol (3dr grills have a wire mesh, not solid like a taxi)
Steve
Old Jan 18, 2012 | 04:45 PM
lukeytheduke
u just answered your own question big boy! Is that just a group a sized one?
Old Jan 18, 2012 | 04:46 PM
GARETH T's Avatar
GARETH T
What are you gaining?
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im not sure about water getting into it when its raining, will it have any effect ????????
Steve
Old Jan 18, 2012 | 04:47 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have no idea thats why i asked the question
Steve
Old Jan 18, 2012 | 04:54 PM
BRAMMER's Avatar
BRAMMER
Pro's and con's really
Looks good
gets it out of the way
away from heat next to the turbo
better air flow
does the turbo cooler get effected with it bang in the way
Old Jan 18, 2012 | 04:59 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Not got one
Steve
Old Jan 18, 2012 | 05:11 PM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
id say its gotta be a better location than standard, especially as its further away from the turbo and should get decent air flow behind the grille.
when i relocated my air filter on my r5gtt it certainly drove smoother especially lower down the rev range
graham c's Avatar
graham c
carnt do any worse than sat behind the head light and near the turbo can it ! think it should be well nice cold air and loads of it
Old Jan 18, 2012 | 05:36 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
ideal if it's for a weekend toy, not for an evey day car...
Old Jan 18, 2012 | 05:38 PM
I dont think Steves car is a everyday car.I would defo get a good cold air feed to it.
Old Jan 18, 2012 | 06:05 PM
martysmartie's Avatar
martysmartie
Steve
I think the Cosworth bonnet louvers are a bad design anyway as the nearside one is right above the coil and the offside one above the cone filter (Admittedly they had airboxes as standard)
Back to the question I don't think it's worth it imo, it may aid induction, but temperature is irrelevant as the air it will be heated up anyway (Hence why you have a decent intercooler)
Also, as you say, if you use the car in rain it will get covered in spray, in Ronnie's situation it's probably isn't an issue as it's used for track etc so far as I can make out?
Martin
Old Jan 18, 2012 | 06:35 PM
GARETH T's Avatar
GARETH T
I think it's a waste of time.
Old Jan 18, 2012 | 07:14 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Get it done big boy!!
Old Jan 18, 2012 | 08:18 PM
Rsmat's Avatar
Rsmat
I would just leave it has it is IMO... WRC guys and the rest didn't change... Rod... Martin... Scs escort never changed there location and your is a puppy compared to all those.
Old Jan 18, 2012 | 08:39 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Seems to be a 50/50 split on peoples views
I will await Mr Moancocks view on the subject
Steve
Old Jan 18, 2012 | 09:00 PM
Brendan's Avatar
Brendan
struggling with reality
water wouldn't be a prob unless it was a sidnificant amount.... remember Team ford have used water injection in their intakes before, as this cools down the fuel air mix and acts as focusing pointws for the flame in the power strokes..... also the presure in the intake system on the intake side ofthe turbo will be higher id are is forced in due to the forward motion of the car, so less effort required from turbo therefore less lag too! then there is the possibity of colder are into ther turbo due to position, this will lead to colder air out as the the heating effect of the turbo is relativly fixed so cooler mix into engine.
The down side would be if the filter fails there is a bigger likelyhood of forign objects getting into the turbo..... and that is not good . that tends to kill engines.
Old Jan 18, 2012 | 09:59 PM
cossiestu's Avatar
cossiestu
Would it be better there than down low, in front of the front wheel? (Like on Martin had on the Reyland Esc. at some point) Obviously with arch liners!
Old Jan 18, 2012 | 10:37 PM
DazF's Avatar
DazF
Designer/Fabricator
ALL race cars, but all felt better throttle response
Old Jan 19, 2012 | 09:15 AM
Fordmad!'s Avatar
Fordmad!
I think its a plus all round! Aslong as you clean it properly more often then you would i don't see many problems apart from alot of water getting in it. Apart from that
Old Jan 19, 2012 | 09:38 AM
stu21t's Avatar
stu21t
When i first built the 5 i didnt bother with an air filter/ pipe.
So it was sucking in hot air from around the turbo.
Then i put 2 90 hoses off the front of the turbo it turned right then down and put a big filter on it and a hose from under the car to give it some nice cold air.
It made quite a bit of difference and more responsive.
Also a mate has a very high power subaru legacy with new impreza engine/running gear. (600 odd bhp)
At one stage on the rollers he gained 70bhp by just opening his bonnet! His air filter was being starved of air and it was hot, as soon as it got lots of cooler air it jumped 70bhp without touching anything lol.
All it will cost you is a couple of hoses off ebay, try it!
Old Jan 19, 2012 | 09:49 AM
RONNIE AMIS's Avatar
RONNIE AMIS
Do it mate. :0)
But will you get slated for nicking the idea like I did
Old Jan 19, 2012 | 11:07 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Originally Posted by RONNIE AMIS
Do it mate. :0)
As much as Airtec for copying the Hart inlet
Steve
Old Jan 19, 2012 | 11:10 AM
R4N SS's Avatar
R4N SS
do it
Old Jan 19, 2012 | 11:14 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im still waiting to hear from Mr Moancock before i do anything.
Steve
Old Jan 19, 2012 | 11:18 AM
Rsmat's Avatar
Rsmat
Steve
If tony said jump of a bridge would you....
Old Jan 19, 2012 | 11:20 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Do you listen to your Tuners advice about your car ?
Steve
Old Jan 19, 2012 | 11:24 AM
Rsmat's Avatar
Rsmat
Steve
No I don't....I do what I want and then let them do the set up / mapping.........
Old Jan 19, 2012 | 11:30 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You have a bloody answer for everything
Steve
Old Jan 19, 2012 | 11:33 AM
Rsmat's Avatar
Rsmat
Steve
Sorry pal... Feel free to get me in the boston crab when you next see me.....
Paul_RS's Avatar
Paul_RS
Works cars used Airboxes, says it all really?
Turbosimpsons's Avatar
Turbosimpsons
you may have to go on cod to find tony at the moment
Old Jan 19, 2012 | 11:34 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Central Day ???????
Steve
Old Jan 19, 2012 | 11:37 AM
James @ M Developments.'s Avatar
Has he got any better, we used to use him as target practice
Old Jan 19, 2012 | 11:43 AM
Rsmat's Avatar
Rsmat
Central Day ???????
Steve
Yea mate.
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
mondeomark
Sep 28, 2015 06:28 AM
