Rebuilding rear calipers
Old Jan 16, 2012 | 09:45 PM
damien roe's Avatar
damien roe
Default Rebuilding rear calipers
guy's is it hard to rebuild rear calipers on a saph i done a few fronts before but i never done one with a hand brake in it
Old Jan 16, 2012 | 10:31 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
very easy i did mine no probs and you dont need any special tools iver you can compress the spring with a socket and a g clamp! then re fit the circlip with a flat blad screw driver
Old Jan 17, 2012 | 01:39 PM
damien roe's Avatar
damien roe
brilliant mate
also the metal plate that the hand brake cable pulls is bent on mine can i just straighten it will it be ok
Old Jan 17, 2012 | 01:42 PM
ajamesc's Avatar
ajamesc
yeah that will be fine on mine the sharfts them levers are on where pitted to fuck so they got filled with chemical metal!
Old Jan 17, 2012 | 09:13 PM
damien roe's Avatar
damien roe
i'll have to give it ago then not looking forward to it at all
Old Jan 18, 2012 | 01:02 PM
BRAMMER's Avatar
BRAMMER
I'm wanting to do mine damo so if you crack on with yours first take some pictures etc and send them over or post on here - i haven't got the seal kit yet but i've seen GGR is knocking them out just shy of Ł30 for the pair so when i get round to the brakes thats the one i'll get.
Old Jan 18, 2012 | 01:07 PM
ajamesc's Avatar
ajamesc
i have a haynes manual bit on doing them from a granarda manual if anyone wonts it and has a fax number ill send it!
Old Jan 18, 2012 | 05:23 PM
damien roe's Avatar
damien roe
could you scan mate and put them up on here
Old Jan 18, 2012 | 06:19 PM
ajamesc's Avatar
ajamesc
i dont have a scanner mate
Old Jan 18, 2012 | 07:23 PM
damien roe's Avatar
damien roe
you better get the crayons out then lol
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
S3an
13
Sep 13, 2015 10:01 AM
cossirob
Sep 3, 2015 09:17 PM
