diff mount ?
Hi all , i took the 3 door out today for the first time since november and noticed the diff seems like its knocking , you can feel it more in reverse ,the car does have a paddle clutch and as you as you hit the biting point you can feel a clonk from the rear. does this mean a new diff mount is needed or is this normal with a paddle clutch ?
Do a search for diff mounts, even if its not the cause of your problem its still a worthwhile upgrade, and I happen to have a MSD mount for sale
pm me if you're interested.
Check the bolts on the diff mounting points to the rear beam and the drive shafts where they bolt onto the diff , mine came loose and it was them that was causing the knocking on mine .
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
