Electric window issue
Old Jan 15, 2012 | 12:21 PM
Nellie's Avatar
Nellie
Default Electric window issue
Hi I have been looking around the site for the answer but cannot find it so here goes,
I have just bought a 2001 Mondeo TD LX with all four electric windows before I completed the purchase I checked each window from the main switch bank in the drivers door, they all worked. Today I have discovered that the passengers side and the rear ones wont work off there individual switches, obviously as they work from the main switch banks its not the motors. If I lower the passengers side from the main bank and then try to use the passengers switch the window only goes up whatever way the switch is pressed.
Any help appreciated
Neil
Old Jan 15, 2012 | 12:46 PM
gouch1's Avatar
gouch1
is there not a locking switch so only the driver can operate the windows
Old Jan 15, 2012 | 04:07 PM
Nellie's Avatar
Nellie
Default electric windows
Thanks for the tip but I think the switch only controls the rear ones when children are on board, The windows do not operate with the isolater switch in either position.
Neil
Old May 22, 2013 | 11:29 AM
big68's Avatar
big68
Default Mondeo mk3 windows
Hello. Did you ever resolve your windows issue only I have a problem with opening and closing windows which isn't the switch cluster. Cheers
Old May 22, 2013 | 12:21 PM
Nellie's Avatar
Nellie
Default Window switches
Hi Yes mine turned out to be the individual window switches and not the main cluster, go on ebay and buy just one at first and try it Removal and fitting is pretty straightforward.
Good luck
Neil
Old Dec 13, 2013 | 02:29 PM
big68's Avatar
big68
52 Mondeo hatchback
Following on from my post some time ago;
Drivers window will go down from the key but not up.
Fuses, window motor/controller, part number 013821771 and drivers door switch cluster all tested and ok.
Other windows from cluster, key and individual switches are ok.
Any ideas please? Thank you
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
cossie330
Sep 27, 2015 04:13 PM
