saab xenon headlight bulb
Old Jan 13, 2012 | 06:15 PM
rsturbolee's Avatar
rsturbolee
Default saab xenon headlight bulb
passenger headlight out oon wifes saab, the computer says dipped, looking everywere i think its a h7 but it has xenon headlights which exact bulb do i need as theres loads of xenon bulbs? or is it any h7 xenon bulb i need?
its a 04 saab 9-3 turbo convertible
Old Jan 13, 2012 | 06:19 PM
rog's Avatar
rog
It's probably a D2S bulb if it's the Xenon one, different from H7's and you can't buy them in most shops. Having said that, I just replaced the xenons in my M5 and it's
only the main beam that's xenon and the dipped IS H7. I shall google it for you and see if
I can find out.
Old Jan 15, 2012 | 09:44 PM
rsturbolee's Avatar
rsturbolee
well on the bulbs theres the sidelight the flasher which looks normal then the one that i presume is the henon thats the one thats out, ive googled d2s and found a place that does the pair of them for 20 quid why is it so difficult to find out which bulb i need
Old Jan 15, 2012 | 10:19 PM
botters's Avatar
botters
competant bodger
usually if a proper xenon bulb has blown its the ballast unit at fault if you fit a new bulb they will usually blow again soon after
the bulbs used to be £80 plus vat each as well when xenons first came about!!!
Old Jan 15, 2012 | 10:39 PM
rsturbolee's Avatar
rsturbolee
i know as my mate told me the other day, only just spent on a dmf clutch and cylinders on it last month, wish i burnt the fecking thing, needs a screen and two tyres also
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
Kam B
Sep 24, 2015 10:40 AM
