RS500 T4 or Escort T34
Old Jan 12, 2012 | 10:17 PM
NoNoCos's Avatar
NoNoCos
Default RS500 T4 or Escort T34
Hi all !
I'm rebuilding my engine on a 2wd, I choose 7.2 Cosworth pistons because I wouldn't have an engine working in low rpm, but now I'm asking myself about the turbo choice...
I was first looking for an Escort T34. But I fear to have a fast power/torque ramp up and spin all the time and having a car without any control on it.
Then I looked for the RS500 T4 (which I ever wanted), I'm thinking to have a more progressive power/torque ramp up, and then having more control, less spin...
I know that with a T4 I will get more power, except if I put less pressure, then my only upgrade will be the pressure.
What are yours feedback regarding this ? regarding drivabillity ?
What about TT T38 ?
Kind Regards
Old Jan 13, 2012 | 09:00 PM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
Whats the plan/usage when your cos is finished ?
Old Jan 13, 2012 | 09:35 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My TT T38 graph
Steve
Old Jan 13, 2012 | 09:49 PM
LHD220Turbo's Avatar
LHD220Turbo
how is the car going to be used? track or road
how much power are you wanting?
the problem with a t4 is, if you dont plan on using it to its full potential, i think you'll find the t4 is not a good choice
what cam do you have?
Old Jan 13, 2012 | 09:51 PM
Paul_RS's Avatar
Paul_RS
ab07 caaaaaaaaaaammmmm
Old Jan 13, 2012 | 10:10 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
And a TT T38 FTW
Steve
Old Jan 14, 2012 | 08:20 PM
NoNoCos's Avatar
NoNoCos
Thanks for answering
I will mainly use the car on the road, fast road, and some trackdays.
Even if it's not fully used, the pleasure is to build something nice, driveable...
I've got an exhaust BD10 and inlet BD14 cams, cosworth 7.2 pistons, airtec plenum, PRO 3" intercooler.
When I see a curve like cossie4i, I think is the kind of curve with I will have no driveability on 2wd...almost 330hp on 1000rpm
Old Jan 14, 2012 | 09:40 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
It drives fine and mine is 2wd
Keep a standard exhaust cam.
Steve
Old Jan 15, 2012 | 05:31 PM
NoNoCos's Avatar
NoNoCos
Between 3500 and 4500rpm isn't it pretty hard if you do full throttle ?!
Old Jan 15, 2012 | 09:16 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Yes it does pull very hard if you put your foot down hard. You dont have to drive like that all the time.
Steve
Old Jan 16, 2012 | 05:07 PM
NoNoCos's Avatar
NoNoCos
Ok, thank you for answering.
Do you think T34 or T4 will do the same ramp up ? (I mean several hp on few rpm)
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Rsmat
63
Sep 25, 2015 12:11 PM
bigryrs
Sep 7, 2015 06:45 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Bighandsuk
Sep 2, 2015 05:23 PM
