Ford Non RS / XR / ST parts for sale. All Ford Car parts in here. (Non RS / XR / ST ONLY please) Starting a topic requires you to have purchased a gold membership.
V-Band GT3076R, Tubular Manifold, Precision Wastegate, Downpipe Setup - *SOLD*
Old Jan 11, 2012 | 05:57 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Default V-Band GT3076R, Tubular Manifold, Precision Wastegate, Downpipe Setup - *SOLD*
Well, as this was all supposedly sold - I made arrangements to get a replacement setup which has now come through so it's time to put this on the market!
The manifold itself is a work of art, it was made to my specifications by Top Speed Performance in the states. Using 4mm wall thickness material TIG welded in an argon purge, there should be NO problems with this cracking!
It uses V band clamps for every connection so everything is very easy to position, remove, refit etc.
The turbo is a GT3076R with a 4" anti surge ported shroud compressor cover and Tial stainless steel V exhaust housing, 0.82 AR.
The wastegate is a 46mm Precision item, again unused, I can supply a selection of springs to be used with it.
The wastegate outlet pipe returns into the downpipe so no problems with noise on track days or similar and there is a flexi pipe on a slip joint to prevent any problems with cracking.
The downpipe is 3" and was made to ensure that air con and power steering can be retained in the standard location. I did however machine a modified power steering pump bracket to use this kit with a Focus RS water pump. To clear the water pump the PAS bracket is spaced away from the head and block, this meant the bolt head was very close to the primary on number 1 cylinder. I modified a bracket to use a recessed bolt and give clearance. This will be included with the sale.
Pics:
Price: Ł2500 o.n.o
Old Jan 11, 2012 | 06:46 PM
Big Will_'s Avatar
Big Will_
Oh, and since I took those photos it's had a lambda boss and an Exhaust Gas Temp probe fitted to the downpipe - I'll include those with the sale!
Old Jan 18, 2012 | 01:36 PM
Big Will_'s Avatar
Big Will_
Sold
timsrs
Nov 13, 2018 11:48 AM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
caprixpack
Sep 25, 2015 07:53 PM
