Are Cosworth handbrake cables all different lengths?
Old Jan 9, 2012 | 01:36 PM
Gav Diamond's Avatar
Gav Diamond
Default Are Cosworth handbrake cables all different lengths?
Does anyone know if the handbrake cables are different lengths from 3dr to Sapphire to Escort or if 2wd is different to 4wd.
Basically I went to fit my rear brakes to the 3dr project and I have a big disk kit so moves the caliper out but the cable would not reach, the cable is a brand new 2wd item.
After messing about for ages I removed the new cable to check it against the old one. On measuring the new cable is 140mm shorter than the old.
Anyone know what lengths the cables should be or if when fitting the 300mm rear disk kit you should use a different cable.
Ta
Gavin
Old Apr 20, 2013 | 11:30 PM
BRAMMER's Avatar
BRAMMER
Gav did you manage to get around this? if anyone knows the answer let me know as i have a similar problem
Old Apr 21, 2013 | 10:04 AM
stevieturbo's Avatar
stevieturbo
C**t
3 door and saph are definitely different lengths. Would assume Escort is too.
Most parts catalogues will list the cable length though. Below taken from Firstline, and I think should all be disc brake models
Sierra 3dr 3380mm
Saph 3380m
Escort 06/92 to 11/92 3150mm
Escort 11/92 to 01/95 3220mm
Granada 3725mm
Scorpio's/Ultimas 3760mm or 3800mm
Old Apr 22, 2013 | 09:29 AM
PAUL S's Avatar
PAUL S
sounds like you have an escos one as they are shorter due to the reduced wheelbase. I believe all the sierra cosworh ones are the same length as they have the same wheelbase
Old Apr 22, 2013 | 05:28 PM
BRAMMER's Avatar
BRAMMER
I think the point has been missed slightly, after fitting bigger brakes and relocating the calipers slightly, on the standard 4x4 setup the cable is fine
JK12
33
Apr 26, 2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Aug 14, 2015 07:29 AM
