No boost
Old Jan 7, 2012 | 04:59 PM
cossie330's Avatar
cossie330
Default No boost
hi, i have refurbished my turbo as it was smoking, put all back together and took for a drive no smoke but also no boost, any ideas?
Old Jan 7, 2012 | 05:06 PM
v man's Avatar
v man
Zee Germans are coming
are all boost pipes on
actuator set correctly
does the turbo spin when engine is running
take the hose off the front and have a look to see
Old Jan 7, 2012 | 05:11 PM
cossie330's Avatar
cossie330
hi, yep turbo spins, all hoses are on and done up tight and the actuator was left as it was when i took it off, although i did notice a deep whining noise coming from the turbo
Old Jan 7, 2012 | 05:13 PM
v man's Avatar
v man
did you get the turbo ballenced
Old Jan 7, 2012 | 05:17 PM
cossie330's Avatar
cossie330
no i didn't, just bought a kit off ebay. thought i would give it a try but may have to pay out for a new turbo
Old Jan 7, 2012 | 08:35 PM
v man's Avatar
v man
turbo chargers are ment to be ballenced to something like 100,000 rpm mate
may be the turbo thats the problem
Old Jan 7, 2012 | 09:35 PM
cossie330's Avatar
cossie330
could be the problem, think i may uprate from a T3 if i change it
Old Jan 8, 2012 | 10:30 AM
dearing5's Avatar
dearing5
did you mark the shaft/nut/wheels up etc??
Old Jan 8, 2012 | 11:59 AM
martysmartie's Avatar
martysmartie
It could be the actuator is not setup correctly, or the turbo, these arn't a DIY job really, thats why a rebuild is costly, as said the balancing is the hard part and is really a specialist job, I guess with the 'Ebay kit' you are merely replacing seals etc?
You can get someone to rebuild your turbo for you, remember if you do decide to uprate it's not just a simple case of 'bolting the new one on', you will need a new chip etc, and unless you have more power in mind, there really is no point!
Martin
Old Jan 8, 2012 | 03:26 PM
cossie330's Avatar
cossie330
Think i have found the problem (bit embarressing really) found one of the blades on the turbine wheel has broken off, didnt notice when i had it apart
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
