Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
internal fuel cell help!!
Old Jan 7, 2012 | 12:51 PM
zs--wilson's Avatar
zs--wilson
Default internal fuel cell help!!
hi there...
soon i will be starting to build my mk 2 but will be relocating the fuel tank inside the car using this fuel cell from pro alloy
http://www.proalloy.co.uk/cgi-bin/si...93&id=proalloy
all lines will run threw the car using braded fuel lines..
but what else would i need...
the car will be running a 2L zetec with bike carbs
will using a Fuel pump ( which has integral pressure regulator) and filter
how would i go about plumbing all of this in? any help would be apreciated
thanks
john
Old Feb 8, 2012 | 10:21 AM
gjh's Avatar
gjh
Seeing as no one has answered you I think the best thing you can do is send Luca (I think thats his username) fast ford contributor. I believe he has a set up like this in his mk3
Old Feb 11, 2012 | 09:09 AM
Luca's Avatar
Luca
Lukesville
Originally Posted by zs--wilson
hi there...
thanks
john
My fuel cell is mounted towards the rear of the car, then -10 hose out of the tank to a small earls filter with -10 inlet/outlet. This feeds into the Bosch 044 fuel pump with -10 in then a -6 adapter out. This leads to a -6 fuel filter then -6 line which runs the length of the car through a -6 bulkhead fitting upto the fuel rail injectors.
Once out the fuel rail it feeds to the pressure reg and out bak through the bulkhead back to the return fitting in the top of the tank. Cycle complete and round and round it all flows.
My advice though if running something like a Bosch 044 pump is run it under the car, the noise they kick out is mind numbing in the car.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
