Ford KA Discuss your Ford KA here!
Vibration since doing clutch
Old Jan 5, 2012 | 10:57 PM
matteoman's Avatar
matteoman
Default Vibration since doing clutch
Hi,
I did my clutch a few weeks ago and now im experiencing a vibration between 30 and 40mph. like i said its only appeared since doing clutch.
It had at the same time new gearbox seals and brand new drive shafts.
what do you guys think? i dont think it could be the clutch as when its roughly alligned with the tool it will sort itself out when i first depress the clutch?? it drives fine other then the vibration
Any help apprieciated guys.
Old Jan 6, 2012 | 05:49 PM
KaTurbo's Avatar
KaTurbo
Why did you change the shafts fella?
Theres a rubber balancer on one that might not be in the right position.
Old Jan 6, 2012 | 06:12 PM
matteoman's Avatar
matteoman
Hi there mate
I replaced the shafts cuz mine litrally fell appart the cv joints was knackered and leaking grease everywhere.
Rubber balancer? i never spotted nothing on the old shafts cuz i made sure the new ones were the correct ones for the car and not missing nothing.
I dont know what could cause the vibrations since i did the clutch atm.
thanks for your help
Old Jan 9, 2012 | 07:34 PM
KaTurbo's Avatar
KaTurbo
Are you sure its the clutch? I would imagine if it was then it would be between a rev range rater than a speed.
Get the front on axle stands (even better a 2 post ramp) and drive it and see if the vibrations still there. It may sound simple but sonething like an unbalanced wheel or a fooked tyre could be the cause.
Rule out the easy things first.
Old Jan 10, 2012 | 03:11 PM
matteoman's Avatar
matteoman
Pm'd you Ka Turbo
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
