Broken Puma
Puma died yesterday and had to be towed home (1.7). Just wouldn't start.
Basically what i did today was take the plastic cover over the spark plugs to be confronted with this:
Mopped it all up and pulled the plugs out which don't seem to have any oil on the electrode end so i swapped the plugs for new ones, cleaned the inside of the leads and put it all back together and it still won't start. just won't quite catch.
is there any way that i can test for a spark or has anyone had this problem?
sorry if I'm a bit rambley its just i really need to get it fixed before monday otherwise getting to work will be real hard.
i had this with my focus when i first gor it, it took ages to start and wouldnt fire on all cyl
al i did was i went to chemist got a baby feeding seringe and sucked the oil out bought 4 sparkplugs and new rocker box gasket cleaned the leads up.. fired first time
as above new gasket needed, but to check for spark, get a screwdriver put it in the plug lead and hold it near the rocker cover and get some one to crank the engine you should see a spark jump from the screwdriver to the rocker cover (do not hold the metal of the screwdriver or you will get a nice belt up your arm from the spark lol)
make sure there is no oil inside the plug lead too
fuel is fine as when it broke down i was in the petrol station having put about 20ltrs in. i shall try cleaning out the plugs although they are brand new and i removed the oil worth a try. ill keep you posted!
definatly didnt put diesel in. well im 99% sure but obvioiusly i am creating doubt in my mind. it doesnt say diesel on my reciept. also i checked the HT leads with the screwdriver test and they all seem to be working fine. all create a spark!
one thing i noticed when i was in it the other day was that there is normally a noise when you turn the key before starting which i always assumed was possibly the fuel pump. is there a way of testing that it is working and if it needed replacing how much of a job is that. i am by no means a mechanic but if i can keep the costs down and its just common sense then im normally alright with stuff like that!
Sounds like a fuel pump issue, as you got into the petrol station and then it wouldnt work after that, its not as if it casually broke down, it was just working fine one minute then not the next?
When you turn the ignition so all the dash lights come on before you turn it again to start the engine, do you hear like a electric whizzing sound and a small clunk from the back seat area? should do it for a few seconds?
If your not hearing that, then you need to check all your fuses first and then the fuel cut off switch which is located in one of the front footwells
not hearing that noise anymore no so guess ill check the fuses. i checked the fuel cutoff switch but it didnt seem to work so i pulled away the carpet and there doesnt seem to be a button to press. may nip home at lunch time and give it a go!
My Puma'd Mk4 Fiesta did this - I changed the coil pack for the spare I had in the garage and drove to work as normal
Your fuel pump won't necessarily prime again if you've already been cranking trying to start the motor (correct me if I'm wrong, people).
Is there a valve on the inlet somewhere, looks like a tyre valve, usually has a cap on it, blue or something in colour, again same as a tyre valve cap would be, remove the cap and press the inner bit, it should spray out fuel for a few seconds then stop, if it doesnt do this, then you know its not getting fuel to the inlet.
checked it again today and it was the fuse for the fuel pump. little diddy fuse as well. well annoyed but i got it working which is great! but the AA man didn't find it so that makes me grin. thank you so much for all the advice guys! really helped me out!
Brilliant news, hope all is well and good again, thought if it blows again, and touch wood it does'nt ! you may need to check the wiring under the back seat and make sure everything is okay and nothing loose.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
