Focus rs upgrade 325mm x 28mm discs and bells £300 delivered
I had a change of plans and am now not using these 325mm x 28mm thick discs along with a pair of generic bells to suit
I know these are what the focus rs boys use to upgrade to over the standard iron discs for better braking and big un sprung weight saving
I was told these discs are genuine ap's but i am not 100% sure but all measurements are the same as ap's and they have the same number of vanes as ap discs (48 vanes) so i assume they are
They are 325mm diameter with 27.2mm disc thickness remaining
they have no cracks etc but 1 has a slight score round it as seen in the photo below where it looks like the caliper has come loose at some point and scored it but it's nothing really, the other disc has no bad marks etc but remember these are used discs
As you can see, for a set of second hand discs they are pretty mint, with nice clean empty grooves
As for the bells they are to suit ford hubs and have a 12 bolt 203.2pcd
The bells are new apart from a few dummy fits so maybe a couple of minor marks, they also have an offset of 17mm, that means the gap from the hub flange to the face of the disc is 17mm or to put it another way the discs will sit 17mm behind the hub flange
There are bolts included but they are no good and should be replaced as ap recommend a 1 time fit only
£300 delivered or £280 collected from Essex SS12
Thanks
Marc
Thanks
Marc
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
