L1 + blacks = ?
Old Jan 4, 2012 | 05:44 PM
jamie956's Avatar
jamie956
Default L1 + blacks = ?
Will seimens black injectors work with a 3 door L1 ecu, what would be the advantage in changing to a L6.
Old Jan 4, 2012 | 09:31 PM
James @ M Developments.'s Avatar
They would work, but I don't think we have any chips off the shelf for the L1,
L6 is no problem though
Old Jan 4, 2012 | 09:43 PM
jamie956's Avatar
jamie956
Well i was looking to get you guys to do my chip, whats the real world diffrence between L1,6 & 8 ecu's.
Old Jan 5, 2012 | 09:17 AM
gray_rs's Avatar
gray_rs
Also which is best ecu out all the cosworths standard ecu's and why?
Old Jan 5, 2012 | 09:55 AM
Just the ecu ability, the early ones are a bit horrible when you come to run large injectors as you just dont have the controlability,
I would asy the L8/P8 are the best to use.As they have the most functionality.
Old Jan 5, 2012 | 02:24 PM
GARETH T's Avatar
GARETH T
What's the smallest pulse a L1 can generate?
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
