Mondeo Diesel throwing out white smoke on acceloration
Old Jan 4, 2012 | 09:15 AM
davidnormanuk's Avatar
davidnormanuk
Default Mondeo Diesel throwing out white smoke on acceloration
Hi all,
I have just got myself a Mondeo Titanium X on a 56 plate with 65k on the clock.
When I put the car under load it appears to throw out white smoke and I'm a little concerned as I have not seen any other diesels do this.
The car has been back to the garage I bought it from and they have advised me that this particular model does this and there's nothing to worry about and they have consulted a diesel specialists to confirm this.
I feel that I am getting fobbed off with this as other Mondeo's I have seen don't do this.
Any advice would be appreciated.
Dave
Old Jan 4, 2012 | 09:29 AM
Is it doing it when its cold.Is it thick white smoke.
Old Jan 4, 2012 | 09:31 AM
LukeDaisley's Avatar
LukeDaisley
If your worried call the aa/ rac as they do independent vehicle inspections, and will be able to tell you what's what. Plooms of smoke is never a good sign, but a little white smoke when cold is expected.
Old Jan 4, 2012 | 09:34 AM
davidnormanuk
Yes it's thick white smoke and it does it regardless of whether the car is hot or cold.
Old Jan 4, 2012 | 09:47 AM
It's Czech Mate's Avatar
It's Czech Mate
Water leak somewhere then maybe
Old Jan 4, 2012 | 09:49 AM
davidnormanuk
I check the levels once a week and nothing's gone down since I got it. The car appears to perform ok and the MPG on average is 48MPG.
Old Jan 4, 2012 | 09:51 AM
daviddunlop83's Avatar
daviddunlop83
Could be the egr valve, They are common to mess up on the mondeo.
Not sure if its the same EGR valve as the ST. Is it a 2.2?
Is it the euro 3 or euro 4 engine?
Old Jan 4, 2012 | 09:57 AM
pani_k's Avatar
pani_k
PassionFORD Member
I would've said water leak or possibly the headgasket.
Old Jan 4, 2012 | 12:17 PM
davidnormanuk
Its the euro 3 engine. 2.0 TDCI
Old Jan 4, 2012 | 12:18 PM
davidnormanuk
I check the levels one a week and they are spot on all the time. No water loss or contaminants in the oil.
I'm limited to what I know when it comes to diesel but previous diesels I've had don't appear to do this.
Old Jan 4, 2012 | 12:19 PM
davidnormanuk
Is there a way to test the EGR valve? It's been on the emissions tester and everything checks out.
Old Jan 4, 2012 | 12:45 PM
daviddunlop83
I think on the euro 3 engine you can just blank them off.
bobsworth
77
Mar 24, 2016 09:30 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Fudgey
21
Sep 30, 2015 06:19 PM
The Enigma
Sep 29, 2015 10:31 AM
SMILER258
Sep 28, 2015 09:04 AM
