Fitting alarm to Sierra
Old Dec 31, 2011 | 04:55 PM
cossie330's Avatar
cossie330
Default Fitting alarm to Sierra
Hi guys, as above fitting alarm to sierra sapphire, need to connect in the central locking any ideas which wiring diagram i need to follow and which wires are what on the car
any help appreciated, Cheers Jason
Old Dec 31, 2011 | 09:56 PM
iansoutham's Avatar
iansoutham
OCD Victim
Negative locking diagram is required.
Go to the drivers or passengers kick panel. Yellow and white are the wires you want for central locking.
Old Dec 31, 2011 | 10:12 PM
dojj's Avatar
dojj
Resident Wrestling Legend
as above, there will be 5 (or possibly 4) wires on a plug
stick your pointy tester into them and see which ones go live when you lock and unlock the door and wire them into that
the 90 spec cars use the same loom but wired the other way around
it'll be more difficult to put the kick panel back on again if you don't tidy up the loom behind it properly, wiring routing wasn't a strong point during assembly
Old Dec 31, 2011 | 11:35 PM
20004x4's Avatar
20004x4
are escorts different to sierras then?
ive just bought a laserline remote locking unit for my mk5a rs2000 and the guys in the shop told me to wire up using the positive diagram?
Old Jan 1, 2012 | 08:27 AM
iansoutham's Avatar
iansoutham
OCD Victim
MK4 Escorts are basically the same as Sierra models, MK5 use positive locking.
Old Jan 1, 2012 | 08:35 AM
20004x4's Avatar
20004x4
thanks for that, puts my mind to rest
Old Jan 1, 2012 | 09:45 AM
cossie330's Avatar
cossie330
Cheers guys, on the negative diagram above I put the 2 ground wires to chassis, then one pulse wire to yellow and other pulse wire to white.
Cheers Jason
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
