2WD wiring loom connections ??
Old Dec 30, 2011 | 10:51 AM
neo's Avatar
neo
Default 2WD wiring loom connections ??
Can anyone point me in the right direction for splicing a 2wd loom into another car loom as im at the point of connecting up the loom to the donor car loom any ideas ??
cheers Rob
Old Dec 30, 2011 | 10:50 PM
mk1yb's Avatar
mk1yb
See if this helps Rob
http://www.turbosport.co.uk/showthre...onnect-to-what
Cheers Stevie.
Old Dec 30, 2011 | 11:09 PM
neo's Avatar
neo
cheers mate
Old Feb 19, 2012 | 09:43 PM
neo's Avatar
neo
In this picture does the solid black wire IGNITION FEED is that a switched ignition positive ???? direct from the ignition switch just want to be 100% before i connect it up thats all...switched positive seemed a weird colour choice thats all black ??? i assoicate it with earth see...
Fuel Pump = Black Red Striped (Thick Wire)
Water Temp = Brown White Striped
Oil Pressure = Brown Green Striped
ECU Diag Light = Brown Red Striped
Rev Counter = Green
Ignition Feed = Solid Black or Solid Red (Thick Wire)
Perminant Live = Red Blue Striped (Thick Wire) or 2 black wires on a 3 Door loom
Old Feb 20, 2012 | 05:10 PM
KENNY G's Avatar
KENNY G
The black is switched from the ignition as per diagram i used the same diagram to wire the loom into my mk2 escort m8 worked for me
Old Feb 20, 2012 | 05:44 PM
neo's Avatar
neo
So its a switched live of the ignition switch yeah not switched earth ?
Old Feb 20, 2012 | 09:05 PM
KENNY G's Avatar
KENNY G
Yes it's a switched live m8
JK12
33
Apr 26, 2021 12:09 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
hopper350
Sep 4, 2015 12:53 AM
Ben26
Sep 3, 2015 07:55 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
