Wire where does this go 2wd loom ????
Old Dec 30, 2011 | 10:48 AM
neo's Avatar
neo
Default Wire where does this go 2wd loom ????
Hi guys im transplanting a cosworth lump into a kit car and fitted the loom a 2wd item, ive a spare wire and have no idea where it goes can anyone help at all...
brown/ white tracer in loom with amal valve ??
its the single wire in picture ???
cheers Rob
Old Dec 30, 2011 | 11:01 AM
Rex Kramer's Avatar
Rex Kramer
Danger Seeker
Not sure mate but this may help
http://www.cannell.co.uk/Ford_Worksh...20Diagrams.pdf
Old Dec 30, 2011 | 11:20 AM
jon@work's Avatar
jon@work
water temp gauge sender
Old Dec 30, 2011 | 11:19 PM
neo's Avatar
neo
Is that for the gauge temp or for the Ecu to read off ?? as if its just for a temp guage on dash only the car loom already has this one in the loom etc...
Old Dec 30, 2011 | 11:28 PM
neo's Avatar
neo
spot on chaps thanks
Old Jan 1, 2012 | 08:37 AM
boost mad's Avatar
boost mad
Wont be the ecu temp sensor, that would have 2 wires and be nearer injector number 4.
As said, most likely dash temp sensor. Are you by any chance using a 4x4 head where the temp sensor is just above the ect at the rear of the head ?
Old Jan 1, 2012 | 09:09 AM
Stu @ M Developments's Avatar
PassionFords Creator
Correct.
Old Jan 1, 2012 | 08:58 PM
neo's Avatar
neo
Cheers guys
Its a 2wd head on a 4wd block...
JK12
33
Apr 26, 2021 12:09 PM
3doorcozmess
Sep 15, 2015 06:06 PM
dojj
28
Sep 11, 2015 10:00 PM
bigryrs
Sep 7, 2015 06:45 PM
rsstav
Sep 7, 2015 04:43 AM
